Daz studio has stopped working error
edited September 2012 in Daz Studio Discussion
It used to work fine but after i installed lux render its giving me this error.So i uninstalled it but its still giving me this error
Apparently only 64 bit gives this error
Post edited by witcherask_a3dd58a1c6 on
  • Richard HaseltineRichard Haseltine Posts: 111,875
    What error? "DAZ Studio Has Stopped Working"? That's a Windows error, and is not terribly enlightening unfortunately. LuxRender shouldn't do anything to DS - to what folder did you install it? Are you using Reality with it? Which version of DS, and of Windows, are you using?
  • edited December 1969
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: DAZStudio.exe
    Application Version: 4.0.3.9
    Application Timestamp: 4ea0acc4
    Fault Module Name: KERNELBASE.dll
    Fault Module Version: 6.1.7601.17651
    Fault Module Timestamp: 4e21213c
    Exception Code: e06d7363
    Exception Offset: 000000000000cacd
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 1033
    Additional Information 1: 72aa
    Additional Information 2: 72aa2d81627fd1600ad646dbf65147a3
    Additional Information 3: b5d6
    Additional Information 4: b5d60427277301c545fdb6c434fe02cd
    Read our privacy statement online:
    http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    Daz is 4.0.3
    Windows 7 64 bit
    Reality 2.0
    It was all working fine untill i installed lux render.However 32 bit version works perfectly
    Unfortunately, this particular error is sort of an 'anything can cause it' Windows error. Yes, it does seem to be tied to specific apps, but more often than not it is not app specific, but rather a symptom of an underlying Windows fault. Luxrender shouldn't have made any changes that could result in this...because the files involved are system files, which Lux doesn't touch. (But that said, it could have been the 'trigger' for it...)
    Are you running Windows updates, automatically?
    Have you recently installed/updated any drivers?
    Last full AV scan?
    Are you running Windows updates, automatically? yes
    Have you recently installed/updated any drivers? It might have automatically updated.But atleast it didnt when i installed lux.I mean it stopped working as soon as i installed lux
    Last full AV scan? long time back
    Does reality 2 works with daz 4.5 i was thinking of installing 4.5 it might work
    This particular error is very difficult to pin down...
