Leg deformation occurs during the loading action(G9)
Leg deformation occurs during the loading action(G9),
As shown in the figure.
1100 x 449 - 524K
  • Richard HaseltineRichard Haseltine Posts: 112,037
    Does "during loading action" mean it snaps back into place when loaded?
  • 793043235793043235 Posts: 36
    edited August 31
    After loading the action shown in the image, the feet become distorted, but I can't figure out exactly where the problem lies.
  • lilweeplilweep Posts: 2,883
    I assume "loading action" means "loading pose".
    What happens when you manually pose the figure in that position (instead of using the pose preset)? Do you see the same effect?
    If so, it is likely to be a morph in your Currently used.  Perhaps view "Currently Used" in Paramaters tab (enabling the Preferences>Show Hidden Properties option) and see if there is any blendshape that is being triggered and causing this deformation.
    Is it any pose or these particular poses? What about posing the bones manually (using a tool with the Viewport gizmos, or the sliders in the Posing or Paramters pane)?
    edited September 1
    That’s exactly right; I resolved the conflict by following your method. Thanks.
