Making an object
jmucchiellojmucchiello Posts: 2,521
I ran a simulation on a plane to turn it into what you see in the image. I froze it and then exported it as OBJ and imported it. How do I get rid of all that dead area that Daz thinks the object occupies? It's just a bag. There shouldn't be anything towering over it And it should just be the width of the bag. Is there some setting in export that I missed?
376 x 1081 - 31K
Post edited by jmucchiello on
  • crosswindcrosswind Posts: 10,351
    edited August 30
    The bounding box in DS covers the whole geometry of an object... i.e. vertex positions of the geometry. For instance, even if there's only one vertex on the top but cannot be seen, the bounding box will cover it ~
    You may try: with Geometry Editor, Vertex Selection mode, Marquee selection, then frame select the top area, see if there's any vertex can be selected ... Also check in Tool Settings > Vertext Selection tab > Details
    Post edited by crosswind on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,755
    edited August 30
    also even if you hide vertices, the points still export
    I see them all on hidden figures in Carrara's vertex room for example exporting fitted draped clothing to create morphs, doesn't seem to prevent morphloader from accepting them though as it only reads faces (ie don't get the vertex order doesn't match dialogue)
    but DAZ will set the bounding box to include the invisible dotty figure if it's reimported as an obj
    Yea, even if the vertices (converted polygons) are hidden, they'll be exported so as to preserve the vertex count as well as UV. Then you still can import the exported object with Morph Load Pro.
  • jmucchiellojmucchiello Posts: 2,521
    edited August 30
    No clue what Morph Load Pro is.
    Geometry Editor did reveal one tiny polygon at the top of the box. Lassoed it and deleted it. And the box now only encompasses the bag itself.
    And FYI, when building that I never hid any polygon. I was just deleting them as my simulation created frayed ends. :)
    edited August 30
    it's a way to load morphs you create for stuff after modifying an exported obj of the figure or prop
    something worth learning about if you want to make stuff
    different dforce drapes can be loaded as morphs for example
    edited August 30
    Are there any good tutorials because loading the dialog tells me nothing about the purpose of Morph Loader Pro? When is it needed? I don't have anything dynamic going on here.
    I've attached a piece of the final render using the bags. If I get bored, I'll create a decal with a big gold colored dollar sign and slap it on the bags. :)
    460 x 448 - 299K
    edited August 30
    probably Jay Versluis (WP Guru) would have some, I would need to Google
    cloudflare not being kind to me
    will just link his channel
    https://youtube.com/@wpguru?si=GbPDRpcsjm9SWZVv
    Google will also help but not me today posting here!
    OK, back after an hour, hope the badgateway has shut itself
    You did well with your money bags yes
    I am only pointing out there are things like morphloader because once the modelling bug bites, tools are handy to know
    any primitive subdivided and bits cut out with the geometry editor can be an outfit with some clever posing, draping, exporting and teimporting as you already realise
    many are daunted by actual modeling softwares so it's a good start and tools that are in D|S can go a long way so worth learning about
    its a shame there isn't a manual
    This took a lot of expermentation. The final run was three primatives:
    • 0.5m sphere, 50% y-scale. Static dForce modifier. y = 150
    • 1.5m plane 50 subdivisions. Dynamic dForce modifier. y=200
    • 1m major 30cm minor. Static dForce modifier y= 125
    The timeline ran for 200 frames. Starting at 60, the torus starts spinning and shrnking until the major radius is 3cm (3% scale)
    The geometry editor was used to trim the "handle". Then it was exported to OBJ and reimported.
    A dFormer was used to give the handle a curved top and that was exported and imported.
    A burlap texture was put on the surface.
