How I can change the color without using "surface" option?
How I can change the color without using "surface" option? I usually click on it and select "Materials" to change the color. I got http://www.daz3d.com/liquid-pack The page says that It have some colors to select but I can't find them
Thanks again!
1366 x 728 - 199K
  • NovicaNovica Posts: 23,925
    edited April 2016
    I don't have this but it says it uses shaders, and it has planes.The way that normally works, you load the plane, then select it in Scene, then go up to the Surface Tool (the three pieces of paper above the viewport) and select the plane. Then you click on the shader. Based on your image, simply select the item in the viewport, click the Surface Tool and apply the shader.
    Post edited by Novica on
  • srieschsriesch Posts: 4,243
    Here are the content thumbnails, names, and file location (your exact file location will differ, but just look at the end part of it):
    876 x 214 - 94K
  • Thanks!!!!
