Morph Loader Pro will not load morph
tam_c3df5332fctam_c3df5332fc Posts: 155
edited August 19 in Daz Studio Discussion
Hey everyone,
Before somone asks - Windows 11 Pro - 12th Gen Intel(R) Core(TM) i9-12900K, 3200 Mhz, 16 Core(s), 24 Logical Processor(s) - Asus ProArt Z690-CREATOR WIFI - Daz Studio 4.20
I am trying to make a morph where a jacket opens up and yet I am receiving an error/warning - Geometry did not match, failed to create morph - see attached screenshot
Yet, if you look at the two jackets in Blender, then you can see that they are the exact same height, width and depth - see attached screenshot
Literally the open jacket is the original closed jacket, with the only difference being that I used Blender to create a segmented front - left and right - followed by using rotation tool to "open" the jacket
How is it possible to receive this error/warning if they are the same jacket, with the exception of two parts rotated almost 90 degrees
Thanks in advance
EDIT: I have added three more screenshots showing settings - when I choose Primary Figure from Graft (Facet Order) - receive a little more information saying that the jackets (objects) are different sizes
1846 x 1074 - 232K
1059 x 788 - 386K
838 x 879 - 43K
827 x 876 - 41K
829 x 870 - 26K
Post edited by tam_c3df5332fc on
  • PadonePadone Posts: 4,377
    You can't split the geometry, to open the jacket. That probably created new vertices and edges. If the original geometry was already splitted then be sure you exported at base resolution.
  • Disregard, the two jackets are not the same - I went into Blender, closed the two open parts, exported the jacket with the name closed at the end, then imported into Daz - Morph Loader Pro worked perfectly
    Sorry, for the initial post
  • Thank you for your response @Padone
    I was able to do the morph because I used the same jacket that I segemented into three parts - I was having the error/warning because I was using a different jacet - very similar but not the original
    I have tried to upload the render, but it does not appear to be working - let me try a jpg - that worked
    It is not perfect but it is my first morph for opening a jacket - not bad
    Thanks in advance
    3840 x 2160 - 292K
