Getting an error from SY 3Delight to Iray Converter
I'm getting an error when I try to run Sickleyield's 3Delight to Iray script. I've tried closing down and reopening the scene and the program and still get the same result. Below are the lines from the log that seem to be where it's having a problem, is anybody to tell me what this means and how to fix it?
2026-08-11 19:43:49.525 [WARNING] :: Script Error (C:/Users/sandr/Documents/My DAZ 3D Library/Scripts/RiverSoft Art/3DL to Iray/RSSY 3Delight to Iray.dse): Line 1752
2026-08-11 19:43:49.526 [WARNING] :: TypeError: Cannot call method 'connect' of undefined
2026-08-11 19:43:49.526 [WARNING] :: Error in script execution: C:/Users/sandr/Documents/My DAZ 3D Library/Scripts/RiverSoft Art/3DL to Iray/RSSY 3Delight to Iray.dse
  • jmucchiellojmucchiello Posts: 2,374
    Are you using DS4 or DS6? I'd assume this only works in DS4 if it works at all. (You may even need DS4.23 or older given it's 3DL.) But the DS6 scripting engine doesn't work with all DS4 scripts.
    It's definitely DS6, i get a simliar error.
    The script works as intended in 4.24.0.3 and 4.24.0.4 beta.
    You will have to wait until Sickleyield updates the asset, if it can be updated. And SY can justify spending time doing the update rather than making something new they can sell. (I don't know if or where SY might have signaled what they plan to do with their backlog.)
  • crosswindcrosswind Posts: 10,339
    edited August 12
    @Sand3  @jmucchiello
    I think both of you meant RiverSoft Art + SickleYield and the script developer is the former smiley
    And yea, having to wait seems to be the only choice ~ The errors just came from the script codes rather than the Material / Shader Presets.
    Edit: Actually I'm not sure if SickleYield writes Daz Scripts but the Material / Shader Presets in this product were made by her ~
    Post edited by crosswind on
    crosswind said:
    @Sand3  @jmucchiello
    I saw SY as the title and not RSSY so I assumed it was SY only. I don't own the asset as I have never ever done a 3DL render.
