[Released] Dark Dungeon [Commercial]
3dLab3dLab Posts: 495
Are you ready to make cinematic gothic dungeon renders?
https://www.daz3d.com/dark-dungeon
How about getting cinematic render in this gothic dungeon?
This project helps you to have a unique fantastic Dungeon experience with realistic building, bone, throne, candle etc..
Also, this complete interior scene includes a complete night scene.
The scene consists of 10 camera settings for each scene ready to render.
  • HellwolveHellwolve Posts: 186
    Looks cool and atmopsheric!
    Who's the character on the throne, and what outfit is he wearing?
  • DasTriDasTri Posts: 275
    I was seriously tempted for the athmosphere and lightning, but in the end I still suffer from the "too many skulls" fatigue by my 40k days. Sorry. That made me also pass Stonemasons "Black Gate". Too obvious to be used in any RPG session for me...
    But nice work. If you ever make one without skulls, I will likely be in.
    edited August 10
    DOUBLE. This forum needs a delete function :-/
    Post edited by DasTri on
  • CybersoxCybersox Posts: 10,038
    It's technically a nice set, but a dungeon usually has cells, shackles, etc., as it's a place of imprisonemt, not a place to put a throne.  Really, short of the one window with a few bars, it's about the least dungeony dungeon I've ever seen.  Ghoulish and creepy, yes, but Dark Throne, Dark Throneroom, or Dark Chamber would have been all much more accurate names that would have at least made this set more likely to come up when some starts searching for what's actually in it.
  • Richard HaseltineRichard Haseltine Posts: 112,067
    edited August 7
    I assume this is "Dungeon" as in "s and Dragons", a generic term for an underground place for adventuring. As I understand it, dungeon derives from donjon, the central keep of a medieval castle, which might well have had a prison and a throne-room.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,845
    prisoners often were kept in towers anyway and tortured there too if not in the public square
    most dungeons were storage rooms full of wine barrels arguably a place one might want to hang out with a cup, a wheel of cheese and hunk of bread
    some rulers had a bit of obsession with collecting their enemies skulls too
    so a throne surrounded by them while getting hammered on ones wine seems on point
    I definitely am adding this to my wishlist as like creepy thrones in themselves
    edited August 7
    According to Websters, the two words Donjon and Dungeon diverged with the original Donjon still being in use to refer to the central keep area while word dungeon refers to the subset of prison.  I do take your point about the usage in D&D and other games, except the convention there defines a Dungeon as a "confined, labyrinthine environment—often a ruined castle, cavern system, or crypt—designed for exploration" and one would be extremely generous to apply that definition to the small setting here.  And either way, it does't change the secondar... and more important to DAZ and the PA... point that anyone who's actually looking for a sinister throne for a project is unlikely to stumble across this one via a store search.  Search for Throne on the DAZ store now and, guess what?  This product doesn't come up.
    Post edited by Cybersox on
    It kind of does, because it looks like the same model is also in 3dLab's "Throne Pack" product (along with a few others, and without the surrounding environment)
    Well, dang.  I own that pack and bought the Dark Dungeon and didn't snap that it was the same prop.  surprise  Not that it matters to me, given that the first thing I did with the Dark Dungeon after installing it was to save a new preset off without the throne and most of the crystals so I could add normal dungeon gear, but I can imagine that not everyone would be thrilled about discovering that they'd double-bought.
  • kielthmp8kielthmp8 Posts: 4
    I also came to ask the same question!
    Glad I'm not the only one curious about that ;-) :-)
  • I bought this a while back when it premiered but it's not showing up in my smart content at all... Also have created a ticket on this issue 6 days ago and still got no reply.
    Anyone else have this problem?
  • How did you install? If you used DIM it is possible, especially if you closed DS and immediately started DIM, that the database was not running when the product was installed. If it was DIM then try uninstaling and reinstalling the product.
  • shyakowskishyakowski Posts: 4
    edited September 27
    If I did install it (which I'm only 90% sure I did at this point @_@) it was from within DAZ Studio itself, not using DIM. I'm even able to manually download the product zip file, so why isn't it showing up in my Installed or Available Content libraries?
    Post edited by shyakowski on
  • Are the files available in the Content Library under Daz Studio Formats (under Daz Connect if that was the isntallation method)?
    They are not (Environments > Architecure > 3DLab). So I did not install them after all.
    But I did buy it, and can download the files manually... What is going on?
  • So it isn't appearing as an install option at all?
    Correct.
    Correct.
    It would help to have corroboration, but in the absence of anyone saying it works for them please open a support ticket. I don't have the set to test it.
