Problems with Updated Now-Crowd Billboards
jjoynerjjoyner Posts: 880
@RiverSoft Art,
During the past several days, updates have appeared in Daz Install Manager (DIM) for a few of the files in several of your billboard products that I have.  After installing them, I discovered today that the scripts Now-Crowd Change Billboard Angle.dse and Now-Crowd Orient Billlboard.dse do not work in the following updated products:
  • Now-Crowd Billboards – Alien Civilizations
  • Now-Crowd Billboards – Modern City Life
  • Now-Crowd Billboards – School Life.
However the above referenced scripts do work in Now-Crowd Billboards – Santa’s Elves even though it was updated as well.
This is what is in the Troubleshooting log file:
2026-08-04 20:21:44.496 [INFO] :: Loading script: E:/My DAZ 3D Library -  Elements SE E/scripts/riversoft art/now-crowd billboards/now-crowd change billboard angle.dse
2026-08-04 20:21:44.496 [WARNING] :: Failed to load script: E:/My DAZ 3D Library -  Elements SE E/scripts/riversoft art/now-crowd billboards/now-crowd change billboard angle.dse
Do you know if something in the updates to Alien Civilizations, Modern City Life and School Life broke the two scripts in each product?
Another of your products, Now-Crowd Utilities, has not been updated since I originally installed in in 2023 and its scripts, Now-Crowd Utility – Change Billboard Angle.dse and Now-Crowd - Utility – Orient Billboard.dse, do work.
1200 x 657 - 124K
Post edited by jjoyner on
  • vwranglervwrangler Posts: 5,056
    You might try posting in one of the Now-Crowd threads, which I think Riversoft Art monitors.
    https://www.daz3d.com/forums/discussion/270591/coming-soon-now-crowd-billboards-school-life-and-asian-school-life-2-products
    My guess -- and it's only a guess -- is that the updates are intended to make the scripts work in Studio 6 -- were you using Studio 4.24 or Studio 6? Maybe they work in one and not the other version?
  • jjoynerjjoyner Posts: 880
    edited August 5
    The forum moderators get upset when you post the same message in two different forums.   :(
    I had just come back to this thread to update that I was using Daz Studio 4.24 on a Windows 10 laptop.  I'm going to explore what happens on another computer that running Windows 11 with Daz Studio 4.24 and 6 but where I have not installed some of the billboard updates.
    UPDATE
    I just tried the School Life, Alien Civilization and Modern City Life products and the same error occurs in Daz Studio 6 when I try to run the Change Angle and Orient scripts.  The log file for Daz Studio 6 provided slightly more detailed info though:
    2026-08-04 21:27:52.321 [INFO] :: Loading script: D:/My DAZ 3D Library/scripts/riversoft art/now-crowd billboards/now-crowd change billboard angle.dse
    2026-08-04 21:27:52.345 [WARNING] :: Script Error (D:/My DAZ 3D Library/scripts/riversoft art/now-crowd billboards/now-crowd change billboard angle.dse): Line 39
    2026-08-04 21:27:52.346 [WARNING] :: ReferenceError: Could not load module at: data/RiverSoft Art/2025Common/RSConstants.dsa
    2026-08-04 21:27:52.346 [WARNING] :: Error in script execution: D:/My DAZ 3D Library/scripts/riversoft art/now-crowd billboards/now-crowd change billboard angle.dse
  • jmucchiellojmucchiello Posts: 2,539
    Not in this specific instance. Ask the mods to close this thread and go post in RiverArt's Now Crowd thread. You want to make this as easy as possible for the PA.
    OK.  Will do.
    @Richard Haseltine.
    Please close this thread and merge it with my short post to RiverSoft Art at https://www.daz3d.com/forums/discussion/270591/released-now-crowd-billboards-school-life-and-asian-school-life-2-products-commercial#latest.
    Thanks.
    jjoyner said:
    @RiverSoft Art,
    DS 4.24.0.4: I have the updated Now-Crowd Billboards – Modern City Life and Now-Crowd Billboards – School Life. I can confirm that Now-Crowd Change Billboard Angle included in both of those product updates does NOT work in DS 4.24.0.4. I did not get errors in the log file, and the log claims it executed successfully, but it didn't do anything at all to change my scene.  Now-Crowd Orient Billboard in those updated products DOES work correctly for me DS 4.24.0.4. I don't know why my experience is slightly different than yours. I may have different versions of some of the "common" script files that the main scripts use.
    DS 6.25.2026.19821: Now-Crowd Change Billboard Angle and  Now-Crowd Orient Billboard included in Now-Crowd Billboards – Modern City Life and Now-Crowd Billboards – School Life DO work in DS6 latest beta. However I get WARNING messages over and over in the log file that "Global include() is deprecated. Refactor ... to use require().
    My guess is that updates were made to work with DS6, and compatibility with DS4 was not regression tested by the PA or Daz QA. Only RiverSoft Art will be able to resolve this, I think.
    edited August 5
    barbult said:
    jjoyner said:
    @RiverSoft Art,
    Thanks for your input.  I am running the last DS 4 version that kept 3Delight - version 4.24.0.3 which is one version earlier than what you are running.  I did get the scripts working in 4.24.0.4 though as follows
    I returned to DS 4.24 on my laptop to explore further and noted that all three of the Now-Crowd Billboard product use the same script files.  I went back to the original Alien Cavillations zip file that I downloaded when I bought the product in 2024 and extracted its files from 2017.  I copied the Now-Crowd Change Billboard Angle.dse script file and the Now-Crowd Orient Billboard.dse script file to my DS library at \Scripts\RiverSoft Art\Now-Crowd Billboards to overwrite the script files that the updates installed.  The two old script files work!
    But now they might not work in DS6. Maybe you don't care about DS6 at this point. If that is the case, you have a successful workaround.
  • NorthOf45NorthOf45 Posts: 5,921
    Note that several Now-Crowd prodcts were updated TODAY (Aug 04),presumably to update the scripts. I am currently downloading to first part (which has all the scripts) of several to see which have actually changed. Since there are many common scripts, installing an older product will revert back to the older versions.
    I haven't gone back to DS 6 on my desktop to overwrite the newly installed scripts with the ones from 2017. I'll try that tomorrow and I suspect (hope) it will work.
    I look forward to your analysis of the update quality. I'll hold off until then. I'm real tired of updates that break things that used to work. It reminds me of the bad old Daz Connect days. I've sworn off Daz Connect forever.
    edited August 5
    Okay, there are basically two versions of the scripts included in each Now-Crowd product.
    One is from literally yesterday 2026-08-03 (or 2026-08-04, same size), the older one is from 2026-07-09 or 2026-07-15 (same size)
    None of the newer ones work in DS4 or DS6. Tried them on the new content they came with, and the older content. Sorry, Tom. I have not installed the Now-Crowd Utilities product, as it appears to be several years old.
    The newer updated packages (from Aug) have utility scripts (not user-facing) in "/data/RiversoftArt/2025Common", whereas the older ones (even from July) have have their scripts in "/data/RiverSoft Art/Common/", so they use different sets of data.
    I installed one of each Now-Crowd sets (Aug and Jul) to test, using both sets of the user-facing scripts from the Scripts folder ("old" and "new"). The old scripts run on both DS4 andd DS6, but the "Change Billboard Angle" does nothing other than face the camera if that option is chosen. The angle does not change in the live preview, nor after accepting. It does work properly in DS6 in live preview and when applied.
    The older "Orient Billboard" and "Move Away" work properly in both DS4 and DS6.
    In short, still needs work.I have included a table of the Now-Crowd products with some relevant info exported crom DIM (I have all but three). You can see there are two versions of the three user-facing scripts that are included in each product. Installing an older one last will at least get some functionality, beacuse those user-facing scripts are common to all (not the ones in the data folder, though)
    ETA: Another one has been updated today (similar to the others from yesterday): Now-Crowd Billboards - Modern Sitting Crowd. I expect there will be more soon.
    And two more: "Now-Crowd Billboards - Sailing the Seven Seas" and "Now-Crowd Billboards - Future Life (01of13)"
    Product Name Product ID Package ID Package Size Package Date Internal script revision date Orient (Bytes) Move Away (Bytes) Change Angle (Bytes)
    Now-Crowd Utilities 69013 1 4347964 2022-06-07T10:42:52Z 2020-05-22 – 2022-05-23
    Now-Crowd Billboards - Barbarian Warriors Cheering (Barbarian Warriors Vol II)(11 of 11) 81874 11 287781106 2021-05-25T11:23:07Z 2026-07-09 4368 4816 6912 Yes, package ID 11
    Now-Crowd Billboards - Barbarian Warriors Fighting (Barbarian Warriors Vol III) (1 of 7) 81952 1 513121168 2026-07-11T10:16:03Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Barbarian Warriors Injured (Barbarian Warriors Vol IV) (01 of 11) 81906 1 319874413 2026-07-11T10:38:14Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Beach Life (01of10) 53519 1 920262644 2026-07-11T11:25:25Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Conquistadors 69775 1 989243654 2026-07-11T12:34:23Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Court Life 59495 1 982891051 2026-07-11T18:14:32Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Disaster! Part 01 of 14 58599 1 651700688 2026-07-11T21:13:33Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Fantasy Life II (01of15) 54269 1 1071267226 2026-07-12T00:12:38Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Fight 61047 1 1234220229 2026-07-12T01:05:18Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - First Responders, Emergency Medical Services (1 of 11) 70203 1 995722659 2026-07-12T10:53:04Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - First Responders Firefighters (1 of 13) 70319 1 725979087 2026-07-12T11:29:43Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - First Responders Police (1 of 15) 70271 1 945389989 2026-07-12T11:59:33Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Future Life (01of13) 52015 1 3840777 2026-08-05T08:10:53Z 2026-08-05 5568 n/a 8496
    Now-Crowd Billboards - Modern Sitting Crowd 66347 1 1450224365 2026-08-05T13:55:31Z 2026-08-05 5568 6064 8496
    Now-Crowd Billboards - Office Life 55681 1 952828557 2026-07-12T17:16:04Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - On the Ice (Winter Fun Vol I)1of10 80295 1 879334782 2026-07-14T00:20:26Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Paparazzi Award Photographers (01 of 10) 82611 1 2351614 2026-07-14T00:47:07Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Paparazzi Camera Operators - Part 1 of 8 82639 1 325223242 2026-07-14T10:13:59Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Paparazzi Reporters (1 of 7) 82634 1 517048881 2026-07-14T16:27:38Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Roman Legionaries Centurions and Aquilifers (01 of 12) 81688 1 511638104 2026-07-15T11:55:10Z 2026-07-09 4368 4816 6912
    Now-Crowd Billboards - Roman Legionaries Charging (1 of 8) 81669 1 349532023 2026-07-15T12:01:30Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Roman Legionaries Fighting (Roman Legion Vol III) (1 of 8) 81628 1 344064906 2026-07-15T15:37:19Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Roman Legionaries Marching Roman Legion Vol VI Part 1 81658 1 2629462 2026-07-15T22:57:56Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Roman Legionaries Guarding (Roman Legion Vol IV) (01 of 08) 81673 1 349061100 2026-07-15T23:19:52Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Roman Legionaries Injured (Roman Legion Vol V) Part 1 of 8 81704 1 366860752 2026-07-15T23:58:38Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Roman Legionaries Ready (Roman Legion Vol VII) (01 of 09) 81661 1 2747848 2026-07-16T00:21:18Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Roman Legionaries Throwing Pilum (Roman Legion Vol IX) 81683 1 2770205 2026-07-16T09:04:39Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Romans 01 of 25 73535 1 344295077 2026-07-16T19:36:06Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Sailing the Seven Seas 69753 1 347114922 2026-08-05T10:25:29Z 2026-08-05 5568 6064 8496
    Now-Crowd Billboards - School Life (01 of 12) 55025 1 1082036823 2026-07-17T00:15:16Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Skiing and Snowboarding (Winter Fun Vol II)1of10 80290 1 608514338 2026-07-19T23:26:05Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Sledding and Snowmen (Winter Fun Vol III)1of10 80302 1 364711923 2026-07-19T23:58:22Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Snowball Fight (Winter Fun IV)1of10 80303 1 317517093 2026-07-20T00:56:56Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Steampunk Empire - Gentlemen 1 of 9 98083 1 657594470 2026-07-20T06:47:55Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Steampunk Empire - Ladies 1 of 10 98088 1 499376968 2026-07-20T12:17:30Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Paparazzi Photographers 1 of 8 82613 1 634268582 2026-07-20T12:29:55Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Steampunk Empire - Working Class 1 of 10 98123 1 530806544 2026-07-20T13:24:57Z 2026-07-15 4368 4816 6912
    Now-Crowd Billboards - Undead Horde (01 of 13) 58057 1 860615361 2026-07-22T12:31:22Z 2026-07-02 4368 4816 6912
    Now-Crowd Billboards - Water Fun (1 of 32) 81325 1 3401123 2026-07-22T22:04:16Z 2026-07-02 4368 4816 6912
    Now-Crowd Billboards - Zombie Apocalypse (01 of 12) 58059 1 1012381272 2026-07-23T08:58:41Z 2026-07-02 4368 4816 6912
    Now-Crowd Billboards Graduation Day (01 of 11) 98181 1 1016917425 2026-07-24T08:41:59Z 2026-07-02 4368 4816 6912
    Now-Crowd Billboards - Ancient Egyptians 78240 1 513990323 2026-08-03T16:34:23Z 2026-08-03 5568 6064 8496
    Now-Crowd Billboards - Ancient World (01 of 36) 74177 1 5746306 2026-08-03T18:03:23Z 2026-08-03 5568 6064 8496
    Now-Crowd Billboards - Asian School Life (01 of 12) 55097 1 763089504 2026-08-03T23:27:57Z 2026-08-03 5568 6064 8496
    Now-Crowd Billboards - Autumn in the City - Children and Couples 87620 1 613676626 2026-08-04T08:21:20Z 2026-08-04 5568 6064 8496
    Now-Crowd Billboards - Autumn in the City - Men1of4 87619 1 1095115009 2026-08-04T09:13:58Z 2026-08-04 5568 6064 8496
    Now-Crowd Billboards - Autumn in the City - Women (1of4) 87621 1 1121604683 2026-08-04T21:22:53Z 2026-08-04 5568 6064 8496
    Now-Crowd Billboards - Party Time01of15 49151 1 1055263733 2026-08-04T21:25:30Z 2026-08-04 5568 n/a 8496
    Now-Crowd Billboards - Barbarian Warriors Charging (Barbarian Warriors Vol I) (1 of 8) 81829 1 507112171 2026-08-04T23:03:12Z 2026-08-04 5568 6064 8496
    Now-Crowd Billboards - Santa's Elves(1of2) 49263 1 1036403944 2026-08-04T23:07:02Z 2026-08-04
    2026-07-15
    5568
    4368
    n/a
    n/a
    8496
    6912
    Two separate folders
    Now-Crowd Billboards - Modern City Life (01of15) 49923 1 937341833 2026-08-04T23:47:31Z 2026-08-04 5568 n/a 8496
    Now-Crowd Billboards - Medieval City Life (01of16) 50397 1 1134728155 2026-08-05T00:46:24Z 2026-08-04 5568 n/a 8496
    Don’t have
    Now-Crowd Billboards - Droids 51939
    Now-Crowd Billboards - Alien Civilizations 52583
    Now-Crowd Billboards - Alien Predators 52587
    Post edited by NorthOf45 on
  • Richard HaseltineRichard Haseltine Posts: 111,929
    Please post to the PA's own threads, which are monitored, rather than posting to this thread, which may not be seen.
