Riversoft's Look at Me III: "An error occurred while reading the file"
Seeker Stock ArtSeeker Stock Art Posts: 83
edited July 23 in Daz Studio Discussion
Has anyone had an issue with Look at Me III not working correctly and found a fix or workaround for it?
For reference:
I'm running Daz 4.24 Publishing Build Beta on Windows 11.
I've had Look at Me II for a long time. It has always worked well for me until recently when it started giving one eye a lazy eye for Gen 9 characters when I used "Look at Camera."
So I decided to buy Look at Me III to see if that would work better for Gen 9 eyes. Except I've not been able to get it to work. Initially I simply installed it via DIM as I would any product. When I selected my Gen 9 character and double clicked on Look at Camera script,  get the error message: "An error occurred while reading the file. See the log for more details." I've perused the log but I'm not sure what they information is telling me other than "script failed to load."
I've troubleshooted in the following ways, but nothing has helped:
Uninstalled Look at Me II
Uninstalled and reinstalled Look at Me III
Restarted Daz Studio
Anyone know of anything else I could try to resolve this issue? I'll paste some of the log info below:
2026-07-23 14:14:08.850 [INFO] :: Loading script: D:/Dazzies Assets/Daz 3D/assets/content/scripts/riversoft art/look at me iii/look at camera iii.dse
2026-07-23 14:14:08.851 [WARNING] :: Failed to load script: D:/Dazzies Assets/Daz 3D/assets/content/scripts/riversoft art/look at me iii/look at camera iii.dse
2026-07-23 14:14:12.400 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 03060 iterations after 01:02.593.
2026-07-23 14:14:18.643 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 03379 iterations after 01:08.836.
2026-07-23 14:14:25.521 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 03730 iterations after 01:15.714.
2026-07-23 14:14:33.179 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 04116 iterations after 01:23.372.
2026-07-23 14:14:38.912 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Updating scene.
2026-07-23 14:14:38.912 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Updating scene took 201.500 us.
2026-07-23 14:14:38.918 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
2026-07-23 14:14:38.919 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
2026-07-23 14:14:38.923 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
2026-07-23 14:14:38.925 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 2 device(s):
2026-07-23 14:14:38.925 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080 Ti)
2026-07-23 14:14:38.925 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU
2026-07-23 14:14:38.925 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2026-07-23 14:14:38.926 Iray [INFO] - IRAY:RENDER ::   1.20  IRAY   rend info : CPU: Allocated 556.285 KiB for frame buffer
2026-07-23 14:14:38.931 Iray [INFO] - IRAY:RENDER ::   1.19  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080 Ti): Allocated 25.612 MiB for frame buffer
2026-07-23 14:14:38.931 Iray [INFO] - IRAY:RENDER ::   1.17  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080 Ti): Allocated 2.094 GiB of work space (2048k active samples in 0.000s)
2026-07-23 14:14:38.931 Iray [INFO] - IRAY:RENDER ::   1.17  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080 Ti): Optimizing for cooperative usage (performance could be sacrificed)
2026-07-23 14:14:38.989 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iteration after 53.016 ms.
2026-07-23 14:14:38.997 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2026-07-23 14:14:39.053 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00002 iterations after 101.519 ms.
2026-07-23 14:14:39.055 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2026-07-23 14:14:39.119 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00003 iterations after 156.869 ms.
Post edited by Seeker Stock Art on
  • barbultbarbult Posts: 27,479
    Look at me III, look at camera, works fine for me on G9 in DS4.24. Instead of starting this new thread, you shoukd post in the existing Commercial thread where the PA will see your message and probably be able to help.
    Thank you. Will do.
