Suppressing Alpha output per object in iray
I do most of my renders in layers (separate render for foreground, bg, ambient, specular, etc...) and then composite after for great control.  However, having a hard time figuring out how to set this up in Daz 4.9 Pro / iray
What I need to do is find a way to render all the objects, but only output alpha for a particular subset of those objects (i.e forground model has alpha on, background has alpha off)
thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,792
    You could use an ID canvas in the Canvasses setcon (Advanced tab of Render Settings) Or do a separate Beauty Pass render for each object.
