Geoshell for G8F: How to turn off hands visibility
dracorndracorn Posts: 2,381
I want to use a geoshell on G8F as an undergarment.  I have Geoshell Visibility Presets, but there is no preset to make the hands invisible while retaining the geoshell visibility on the arms.  I tried using Geometry Editor, but I can't seem to get it to affect the geoshell.
I want to hide the hands on the Geoshell, not on the G8F figure itself.  Genesis 8 does not have a separate surface for hands, so I can't do it there.
Post edited by dracorn on
  • ElorElor Posts: 4,153
    edited July 19
    Did you try to hide the hands yourself?
    The geoshell should not be affected by the visibility of the hands. Here's an example with a basic geoshell on a Genesis 8 figure who have all her bones hidden:
    If it's not working, maybe the geoshell you're using has an opacity map to hide the whole arms surfaces.
    1184 x 1035 - 123K
    Post edited by Elor on
  • dracorndracorn Posts: 2,381
    I want to hide the hands on the Geoshell, not on Genesis 8 Female.
  • crosswindcrosswind Posts: 10,314
    edited July 20
    You want to turn off Visibility of lHand, rHand, lThumb1~3, rThumb1~3, lIndex1 ~ 3, rIndex 1~3, lMid1 ~ 3, rMid1 ~ 3, lRing1 ~ 3, rRing1 ~ 3, lPinky1 ~ 3, rPinky1 ~ 3. Then save a Properties Preset, just in case they'll be reset by some tools.
    Or, you can make a black/white texture map as per G8F's diffuse map, assign it to Arms and Fingernails surfaces to hide the hands on the geoshell.
    2017 x 1293 - 582K
    2021 x 1294 - 867K
    Post edited by crosswind on
    Ah HA!
    It's not in the Scene tab or the Surfaces tab, but on the Parameters tab.
    Thank you!
