Large number of [WARNING] items
At some point, my Daz installation started throwing large numbers of items like:
"2026-07-19 10:00:25.500 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(595): Formula output property not found:
File: /data/Daz 3D/Genesis 9/Base/Morphs/kooki99/KOO Elea/Elea_proportions.dsf"
On loading a G9 figure*. It happens when loading the default G9 figure, or a saved file with a G9 in it, etc. (*I've confirmed that I get some when loading a G8 base figure. I've uninstalled most of my G8s but there are still are a few and I get warnings just like this.)
I found these by chance, when looking for something unrelated. I don't know when this started happening as I don't have a collection of logs over time.
It only occurs to some items. For instance, this is the only one related to KOO Elea. (In fact, it's the only one related to KOO figures, of which I have dozens.) And the file is actually there:
I have my doubts that they're actually meaningful errors, as the Elea Proportions morph is available and appears to do what one would it expect it to do to a stock G9 figure. I've found similar when testing other examples. It occurs across a wide variety of PAs and also with some of my own saved morphs. But if possible, I'd like to get to the bottom of this and fix it, so these aren't clogging up the log.
810 x 143 - 28K
Post edited by paulawp (marahzen) on
  • jmucchiellojmucchiello Posts: 2,631
    The problem is they are important if you are applying KOO Elea to a figure and they aren't important if you aren't.
  • That's an interesting point. I located a random other figure that does not have a warning like this for proportions: ES3D Cassidy, just a figure with a proportions dial picked at random. When I load a generic G9 figure and apply the "ES3D Cassidy" dial, it applies the Body, Proportions and Head items along with it. The same test performed with the "KOO Elea" dial applies the Body and Head items, but not the Proportions item. I can manually dial Proportions and it does work - it's just that it's not connected to the main dial.
    Is that what the warning is actually about - that there's a disconnect? And if so, how might one fix it?
    Just to note, the original example was picked at random. The warnings involve various morph aspects for assorted figures - not just proportions.
  • ElorElor Posts: 4,252
    I'm not sure there is a rule about character dial being linked with that same character proportion dial or other needed shapes: they are simply too many examples of the older core characters whose character dial won't load the proportion dial (Victoria 9, Olympia 9, Ivar 9, Michael 9, Nikolai 9, etc) or the needed shapes for alternative shapes (Mira 9 Young Adult or Victoria 9 Masculine are not loading Mira 9 and Victoria 9 head and body).
