DogZ & Zev0 200 Plus Morphs G9 Error
nightwolf1982
Well, here's one that threw me.
Loaded G9 and checked the log for errors, got a Formula output property not found error from the Brian and Anya morphs:
2026-07-16 06:06:37.921 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(595): Formula output property not found:
File: /data/Daz 3D/Genesis 9/Base/Morphs/DogZ&Zev0/200 Plus/DF-200BrianHead.dsf
URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/VOOTW/Vo%20Yonina/Vo%20Yonina%20Mouth.dsf#Vo%20Yonina%20Mouth?value
2026-07-16 06:06:37.922 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(595): Formula output property not found:
File: /data/Daz 3D/Genesis 9/Base/Morphs/DogZ&Zev0/200 Plus/DF-200AnyaHead.dsf
But the shop page for 200 Plus doesn't show Vo Yonina as a required product: 200 Plus Genesis 9 Edition | Daz 3D
So do we need VO Yonina, or does the product need to be updated?
That's weird... such head morphs from 200 Plus shouldn't have ERC links to other character products....
Can you try: locate the dsf file in data folder, open it with Notepad++, see if you can locate any formula related to Yonina or VOOTW by searching these words ?
It's the very first formula in both dsf files.
It struck me as odd, since the store page doesn't list Yonina as a requirement; that's why I'm wondering if this is a mistake and the product needs an update.
So, you don't have Yonina product and have not installed it before.... but did you ever modify these DSF files or did Save Modified Assets... with them selected ?
I have 200 Plus G9 product and these two file stays intact with Date of Modified 2023/9/13... You may try reinstalling the package in DIM. I think the issue will be gone ~~
No, never bought Yonina, and re-installing didn't fix it. Mine show the Anya morph modified 8/23/2023 and the brian morph modified 9/23/2023.
Ah, I found there's an updated package marked hidden in my DIM > Ready to download. Anyway I kept the older version and installed the latest one. Yes, I could reproduce the issue ~~
I think when Zev0 saved these morphs, Yonina Mouth property had a value 1.0 for some reason....(or maybe they made the morph by using this PHM but didn't bake it ~~ ? )
Now you just need to delete the forumula from DSF files... The issue can be fixed ~
Check the screenshot down below~ Do the same in Anya's DSF.
Wow, I was really surprised. After updating this product, my DS log that used to have 0 warning, 0 error when loading G9 now has this warning:
I can't believe it comes from a morph ever made by Emma and Jordi who left this store long time ago ~~
Hmm, I'm digging out the culprit ~~
The culprit is in : 200_head_bs_Eye Lids Lower Sag.dsf
1) Go to line 16, replace Eyelids Lower Volume Wide-0xa0f81af with 200_head_bs_Eye Lids Lower Sag-0xa0f81af (ss2)
2) Go to line 341, replace #EJFM%20Eyelids%20Lower%20Volume%20Wide-0xa0f81af with #200_head_bs_Eye Lids Lower Sag-0xa0f81af (ss3)
@nightwolf1982 Thank you for posting the issue !
Emma and Jordi's DAZ store is closed, but their some of their stuff is still available on Gumroad, including the face morph sets
Yup, I know. I ever bought some items from their gumroad store ~
Thank you for sharing this information.
The problem is resolved; everything is working fine for me.
