FBX exporter incorrectly solving bone orientations
When i export my figure in FBX all bone orientations become messed up and unusable for posing (Impossible to correctly bend an elbow for example). Also "Export Subdivions" check does nothing. I tested Blender and Max import and both problems are there. I've tried all available FBX export options and different fbx versions, but nothing helped.
I've used an older version of DAZ Studio some years ago, like a version ~4.12 or so and FBX export worked perfectly, i used it to import figures into 3ds Max with correct bone orientations and skinned high resolution meshes. So what happened? This is really frustrating.
The only solution i've found so far is to use Daz to 3DS Max Bridge, which gives me a CAT Rig with correct bone orientations, but the dummy bones that the figure is skinned to are messed up too. So its not really good solution.
  • Richard HaseltineRichard Haseltine Posts: 111,947
    What export options are you using?
  • lanayafanlanayafan Posts: 2
    I use these, but it seems some options are either ignored or do nothing. I tried checking Include Rotation Locks, Include Rotation Limits, Include Animations, but nothing solves the problem.
    Basically all Local Rotations data for the bones is not there when i import FBX to Blender or Max.
    904 x 836 - 42K
    811 x 902 - 66K
    970 x 972 - 234K
  • crosswindcrosswind Posts: 10,351
    edited July 16
    I don't know 3ds Max but I know FBX format doesn't support subdivision levels other than base mesh for import / export. Blender itself can export / import FBX format with subd levels by using subdivision surface modifier but can only be used within Blender.  DTB bridge and diffeomorphic addon can import and preserve subdivision data by using subdivision surface mofifier but the former only support to Blender 4.x, so using diffeomorphic could be a good choice.
    As for the bone rotation issue, Blender's built-in FBX importer is pretty weak which cannot handle FBX file exported from Daz Studio and a few other applications... that's why there's a stronger add-on called Better FBX Importer/Export developed for the folks who use native FBX file in their workflow. The add-on does work it out (see screenshot down below..an FBX format of G9 imported by the add-on)
    So, still suggest you use diffeomorphic with the pipeline of Daz Studio > Blender or DTB if you use Blender 4.x ~~  BTW, USD format fully supports all these but unfortunately Daz Studio doesn't support USD ~~
    2560 x 1392 - 619K
    Post edited by crosswind on
    Well its still upsets me that at one point the FBX import/export worked completly fine and now it doesnt. My workflow requires Max, so sometimes i have to use Blender as Bridge, but the FBX that the current DAZ Studio spits out is even more messed in Blender than it is in Max. I have yet to try DTB or Diffeomorphic.
    edited July 16
    I started learning and using Blender from ver 3.6, FBX files exported from DS never really worked well for me in Blender until I used Better FBX Importer. Then I stopped using native FBX when I knew diffeomorphic addon.
    Frankly speaking, the latest FBX Importer / Exporter in DS are the best versions up to now as Daz fixed quite a few bugs in there~
