RSSY 3Delight and Iray to Filament
Need some help here... 3Delight and Iray to Filament won't load in Daz 4.24. It gives the "An error ocurred while reading the file" message. Here's the log file. Thanks in advance.
2026-07-11 22:56:57.510 [INFO] :: Loading script: D:/Daz Connect Data/data/cloud/1_80055/scripts/riversoft art/rssy 3delight and iray to filament/rssy 3dl and iray to filament.dse.enc
2026-07-11 22:56:57.510 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(203): Invalid file header for encrypted file: "D:/Daz Connect Data/data/cloud/1_80055/scripts/riversoft art/rssy 3delight and iray to filament/rssy 3dl and iray to filament.dse.enc"
2026-07-11 22:56:57.510 [WARNING] :: \src\sdksource\general\dzscript.cpp(2735): No stream from CloudFile D:/Daz Connect Data/data/cloud/1_80055/scripts/riversoft art/rssy 3delight and iray to filament/rssy 3dl and iray to filament.dse.enc
  • crosswindcrosswind Posts: 10,334
    The script product installed via Daz Connect cannot work ~~ You have to install the product 80055 by using DIM.
  • StingerStinger Posts: 328
    Thanks, crosswind. It initially didn't work when I used DIM, but I deleted the data in the Daz Connect folder, re-installed and now it's working.
  • LeanaLeana Posts: 13,577
    If something is installed with both Connect and DIM then DS with use the Connect version. So in cases like this you need to uninstall the Connect version too, not just install it with DIM.
    Thanks, Leana. I'm learning that the hard way...  smiley
