Cannot Apply Translation to Thigh Sheath
I have the Warrior Outfit for G9. I have applied the thigh sheaths to a G8 male.
It works fine. Need to fix some poke through issues.
However, I decided that I wanted to move the sheaths further up the characters thigh but I am not able to move them. I can move the knives that go in them, but not the sheaths themselves.
I have unparented them but still cannot get any sort of translations to work on them.
Is there a change I need to/can make to allow me to adjust the vertical positioning of these sheaths?
thanks,
DJ.
  • crosswindcrosswind Posts: 10,341
    They cannot be translated because they're fitted... you must've Auto-Fitted them on a G8M.
    The easiest way: with a sheath selected, in Parameters pane, change Fit to Mode to Auto Follow Transforms, then you can tweak X / Y / Z Translates a bit.
    Or, if you have Mesh Grabber, select the whole sheath, drag it up.
    2021 x 1294 - 290K
  • Thanks for the help, I have Mesh Grabber but used your first suggestion and that worked just fine.
