D force dilema
deeahr2169deeahr2169 Posts: 497
I have a Mac Mini M2 which remains by and large as it was when I purchased it. I cannot use Dforce because my machine does not support Nvidia graphics, well I can use Dforce but its like watching paint dry and the results are pretty much a lottery. I think that as a mac user i am caught between some kind of war involving Apple and Nvidia, which makes using Dforce virtually impossible for me. Is there anything apart from switchin g to a windows set up with Nvida graphics that could be emplyed to make this very technology available to the many Mac users...
  • garrett_3dgarrett_3d Posts: 1,041
    Have you tried switching from GPU to CPU in the OpenCL dropdown on Simulation Settings/Advanced?
  • crosswindcrosswind Posts: 10,351
    OpenCL doesn't really work well on Apple Silicon, as you said, virtually impossible if working for dForce ~~
    If you want to make dForce work as expected, you’ll need an Intel-based Mac with a GPU driver that supports OpenCL 1.2+ required by DS 4.x / 6.x.
  • ElorElor Posts: 4,236
    edited July 4
    It's slower compared to using a Nvidia GPU, but it's still usable on my M1 Pro.
    If, while using it, Daz is using all the cores availables (you can check with Activity Monitor), making your computer unresponsive, you can change the device used by dForce (they likely have the same name) and it should stop using all cores and the simulation should proceed.
    Post edited by Elor on
