Genesis 9 error loading both Daz 4.24 and Daz 6
Whenever I try to load a Genesis 9 figure I get the following warning in the log file:
2026-06-23 19:48:00.791 [WARNING] :: Could not resolve: /_temp/002.duf
As well as an error popup in the program itself.  It seems to load the figure properly, and there are no other errors in the log file after this one.
Does anybody have any idea what this is about, and how to fix it?  I'm assuming there is a termporary directory somewhere it is looking for and can't find, but I don't have a clue what it is.  I have three computers on a home network, they are all running DAZ locally and they are all doing it.  Windows 11.
  • BejaymacBejaymac Posts: 2,014
    edited June 25
    Try unistalling recent installed content until the error goes away, odds are a character or morph pack has a "bricked" file.
    Post edited by Bejaymac on
  • crosswindcrosswind Posts: 10,356
    DS has no default temporary folder of sth. like "_temp"... but since it seems to load a DSON user file, especially if you loaded a Character Preset of G9 figure, you could check if there's anything relatively defined in the Post Load script of the Character Preset.
    i.e. select the loaded figure in Scene pane, save a Character Preset, then you can see a Post Load script is checked, click the edit button and check if there's anything strange.
    Besides, name the product that you use if you can...
  • Richard HaseltineRichard Haseltine Posts: 112,000
    The location of the Temp folder, used for things like the temporary baked versions of Layered Images, is set in Edit>Preferences. The default, for Windows, is
    %appdata%/daz 3d/studio#/temp/
