[Solved] How to delete a saved dimension preset?
Joe827Joe827 Posts: 272
I saved a new dimension preset as an experiment, but I don't see how to delete what I saved.  Thank you.
347 x 154 - 11K
291 x 794 - 34K
Post edited by Joe827 on
  • crosswindcrosswind Posts: 10,248
    Drop down the list of Dimension Preset, there's a menu item named : Remove User Preset.
    Delete the preset by clicking it...
    663 x 1163 - 145K
  • Joe827Joe827 Posts: 272
    edited June 23
    Sorry, for not mentioning it.  I'm using Daz 4.24.  "Remove User Preset" is not present on mine.
    Edit: From your screencap, you're using 4.24 as well.  Interesting....
    312 x 838 - 40K
    What style/layout is that you're using?  Maybe that has something to do with why it's missing on mine...
  • Richard HaseltineRichard Haseltine Posts: 111,348
    I don't see a user preset in that list, they are usually separated from the built-in presets (which can't be deleted).
    edited June 24
    3x2 and 1920x1080 (the two at the bottom) are the two that I saved, and yes, for some reason, they're not separated from the rest like crosswind's.
    Odd, what is the exact version number (from Help>About Daz Studio - it should be four numbers separated by dots).
    I uninstalled before seeing your message, so I don't know.  However, upon reinstallation using 4.24.0.4, everything looks as expected now.  Sorry for wasting your time.
    386 x 865 - 56K
    May have been an issue with one of the installed files (uninstall/reisntall isn't always a fix, but sometimes it is).
