Wash Down room only iray materials?
LinwellyLinwelly Posts: 6,070
I'm only now having a closer look at the Wash Down http://www.daz3d.com/wash-down, it gerneally comes with bot Iray an 3delight but the material for the room itself seems to be only Iray. There are even two files there and I made sure to test both but the surface urns out to be Iray in both. Is there a file for 3delight missing or am I missing something?
Generally speaking I would appreciate it very much when the icons or the title for the materials contain an indicator for Iray or 3delight. I know some products have it and the older products don't even have Iray but with the newer ones, the need to go look up in the surfaces in a bit annoying.
  • SorelSorel Posts: 1,434
    edited March 2016
    Maybe reset the surface to daz default and try applying again
    Post edited by Sorel on
  • LinwellyLinwelly Posts: 6,070
    Thanks Sorel, I will try that as soon as the current render is through
