Meaning of the "Parenting Data" Checkbox
HI,
I would like to package multiple props that have parent-child relationships into a single prop.
My understanding is that this is not possible due to a limitation of Daz Studio, and that such content must instead be saved as either a Scene or a Scene Asset.
However, I noticed that the Save As > Support Asset > Figure/Prop Assets dialog contains a "Parenting Data" checkbox, which made me wonder whether this might actually be possible.
The problem is that, for some reason, I cannot enable this checkbox.
Am I misunderstanding how this feature works? Is it possible to package multiple props into a single prop asset rather than saving them as a scene or scene asset? If so, what is the purpose of the "Parenting Data" checkbox, and under what conditions can it be enabled?
Any clarification would be greatly appreciated.
  • crosswindcrosswind Posts: 10,341
    edited June 16
    The option of Parenting Data can be only used for the case that you Parent non-rigged items (Props) to a Figure, i.e. the Parent of the Props has to be a Figure.
    In your case, you parented some Props to a Prop, you need to firstly save each Prop as a Figure/Prop Asset, then save a Scene Sub-set with the Parent Prop selected. Using a Scene Asset is not really suggested.
    Post edited by crosswind on
  • flare_dbd185b4baflare_dbd185b4ba Posts: 90
    edited June 17
    The parent prop has been converted to a figure and contains a rig.
    The two child props do not have rigs and are parented to it. In this case, is the option still unavailable?
    Post edited by flare_dbd185b4ba on
    edited June 17
    No... that's not how Parent Data works. You should've selected the children Props one by one to save a Prop asset rather than selecting their Parent. (It's just like the way you save a rigged clothing as a Figure asset...)
    Then when you load the saved child Prop to the selected figure, the Prop will be smartly parented to its parent Bone accordingly. Check the screenshot down below ~~
    PS : Be noted that when you save a Figure / Prop asset,  you can only save the selected item... None of the parented children item can be saved together. That's how Save Figure/Prop Asset... works.
    1703 x 1292 - 189K
  • I understand the meaning of the "Parenting Data" checkbox now. Thank you very much for your help.
