Creating Shortcut Buttons
I use the "!Iray Uber Base MDL shader" in "Default Resources" often. Is there a simple (me not smart) to make a button in top tool bar to serve as a shortcut for this one shader? I want to avoid having to navigate to it all the time. Thanks in advance for any help.
  • Richard HaseltineRichard Haseltine Posts: 111,734
    Right-click on the preset in a content pane, select Create Custom Action. That will let you add it to the Scripts or favourites menu in the main menu bar. If you then go to Window>Workspace>Customise you should find the action under Custom on the left. On the right, open the Toolbars tab and then drag the preset from Custom on the left to the place in the toolbar you want on the right.
