Daz Studio assets (DSON user files (.duf)) not loading after being clicked, once daz has started
Daz Studio assets (DSON user files (.duf)) are not loading after being clicked. But strangely, the first duf (e.g Genesis 9) being clicked is opening normally, then the clothes, hair, etc, nothing is loading.
But they are working normally if dragged and dropped onto the already open daz software. also loading normally if clicked from the content library pane. Pls help!
  • felisfelis Posts: 6,561
    You are aware that you should doubble-click?
    What does the log say, Help > Troubleshooting > View Log?
  • Richard HaseltineRichard Haseltine Posts: 111,745
    There is, or was, an option to have Windows treat a sngle-click as the default action; like clicking a weblink.
  • crosswindcrosswind Posts: 10,341
    To confirm, you were trying to load DUF files from Smart Content ? by dbl-clicking the thumbnails ?
  • I have single click enabled, but have even tried double/multiple clicking. Nothing happens.
    Even the log shows nothing when i click the duf file. but whenever i drag it into the software, it functions normally and a bunch of lines are added in the log file
  • MajormanagerMajormanager Posts: 6
    edited June 13
    No. i click from the content library, not the smart thing
    So you start DS, you go to the Content Library pane in DS, the first item you try to load loads but nothing else does? Or are you starting DS dy opening a content file from the Windows explorer?
    edited June 14
    I'm opening a content file from the Windows explorer directly. after it loads, nothing else (duf) opens
    OK, yes I see thast. But I would generally expect to use one of the content panes inside DS once it was up-and-running. I am not sure if this behaviour is a bug or expected.
    That is working. Only clicking the duf from windows explorer is not.
    edited June 15
    I tested the way you load DUF files, firstly loaded a DUF (Genesis 9) from Windows Explorer, DS opened it with no problem. Then loaded other DUFs (a clothing, an accessory, a prop....) from Windows Explorer again, DS also loaded them well.
    Edit: Then I changed the default application to open DSON User files... all builds of DS 4.x and DS 6.x worked well.
    Post edited by crosswind on
    edited June 15
    Exactly! earlier, it used to open from explorer itself, but now the other dufs don't open AFTER any duf is already open in DS
