How can I reduce tank top wrinkles
Hello, I’m trying to fit a tank top on a Genesis 9 female character and I’m having trouble with horizontal wrinkles under the bust and around the upper abdomen area. I have fit control also. Is there any solution for this? Thank you!
506 x 532 - 318K
  • felisfelis Posts: 6,534
    Is it actual geometry or a normal (or bump) map?
    Can the shirt be simulated?
    Does it look like that on other characters?
  • ekaratas20ekaratas20 Posts: 8
    1) I think it is actual geometry. 2) yes 3) Yeah,same wrinkles
    Which shirt is it?
    Have you tried simulating it?
    If simulation doesn't work, my suggestion would be to make a morph that smoothes out the wrinkles. Best done in a modeller, but if you are Premier, you should have acces to "Sculpture" (I think it is called), which has a smoothing function.
  • PrefoXPrefoX Posts: 329
    edited June 18
    it just looks like a normal map, there is no visible geometry at the left and right side of the shirt. just turn of the normal map or bump/heightmap
    Post edited by PrefoX on
