How can I make Custom Dials. to moving two or more dials with one dial
myotherworldmyotherworld Posts: 665
edited June 11 in The Commons
[How can I make Custom Dials. to moving two or more dials with one dial] I recall seeing a post some time ago, that it is possable to make custom dials.
But for the life of me I cannot find it.
Can anyone point me in the right direction.
As always, thanks for any help.
(Ds4. what ever it is. NOT DS 6)
  • Richard HaseltineRichard Haseltine Posts: 111,859
    1. Set the sliders you want to control to the values you want them to have when the contoller is at 100%
    2. Right-click in the Parameters pane and put it in Edit mode (if it isn't already checked).
    3. Right-click in the Parameters pane, in the group you want to have the controller, and select Create New Property.
    4. Give it a name and label, set the path f you missed the deal group, adjust limits (e.g. you might not want it to drop below 0) and click Accept
    5. Set the new property to 100% (you don't want thata s th default value)
    6. Right-click on the new property>ERC Freeze
    7. Check that only the properties you want to control are listed as Sub-compinets, uncheck any interlopers, and click Accept.
    Makes ure everything works, if t does then save (as a scene or character preset if you just want it in this scene or a few others, iif you want t always avalable then use File>Save As>Support Assets>Modifier Asset (n.b. not Modified Assets, that is completely diffrent). The Author and product fields determine  folder names n the Data folder.
  • myotherworldmyotherworld Posts: 665
    Thanks Richard.
    i give it a try ASAP. I am working on a kitbash of a Maglev train atm and it didnt have opening doors.
    It has now but I want to control them in groups.
    So this will help a great deal.
