[Help] Suddenty unable to do anything in Iray
Hi there,
I'm having a weird issue.
Iray no longer appears to work for me. This started this morning.
Essentially, I load any reasonable scene, with a couple of figures, an environment, a few props etc, something I've been able to render already (I've tried 30-40 old scenes so far), and as soon as I go into Iray preview, Daz crashes.
Here's an example from the log:
2026-06-11 00:14:48.635 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
2026-06-11 00:14:48.638 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
2026-06-11 00:14:48.639 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled environment code.
2026-06-11 00:14:48.639 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
2026-06-11 00:14:48.699 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment textures.
2026-06-11 00:14:48.699 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
2026-06-11 00:14:48.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
2026-06-11 00:14:48.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
2026-06-11 00:14:48.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
2026-06-11 00:14:48.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
2026-06-11 00:14:48.703 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
2026-06-11 00:14:48.703 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled backplate code.
2026-06-11 00:14:48.703 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate textures.
2026-06-11 00:14:48.703 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
2026-06-11 00:14:48.757 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
2026-06-11 00:14:48.766 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
2026-06-11 00:14:48.769 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
2026-06-11 00:14:48.770 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
2026-06-11 00:14:48.806 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 11 cores for rendering
2026-06-11 00:14:48.824 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
2026-06-11 00:14:52.061 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 2 device(s):
2026-06-11 00:14:52.061 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4080)
2026-06-11 00:14:52.061 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU
2026-06-11 00:14:52.061 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2026-06-11 00:14:52.062 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend progr: CPU: Processing scene...
2026-06-11 00:14:52.063 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 4080): Processing scene...
2026-06-11 00:14:52.067 Iray [INFO] - IRAY:RENDER ::   1.14  IRAY   rend info : Initializing Embree
2026-06-11 00:15:10.739 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IMAGE:IO ::   1.12  IMAGE  io   error: The image plugin "oiio_jpg" failed to import "C:\Users\redacted\Documents\DAZ 3D\Studio\My Library\Runtime\Textures\Daz\Characters\Genesis9\Base\Eyelashes\Genesis9_Eyelashes02_NM.jpg".
2026-06-11 00:15:10.819 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IMAGE:IO ::   1.10  IMAGE  io   error: The image plugin "oiio_jpg" failed to import "D:\Library2\Runtime\Textures\Daz\Characters\Genesis9\Michael9\Michael9_BodyM_D_1002.jpg".
then the crash.
This is happening in 4.24. In 6, the issue is different, I click Iray preview and it sits there loading Iray preview until the end of time. It doesn't actually do anything.
Here are my system specs:
         Operating System: Windows 10 Home 64-bit (10.0, Build 19045) (19041.vb_release.191206-1406)
      System Manufacturer: Micro-Star International Co., Ltd.
             System Model: MS-7D17
                     BIOS: 1.20 (type: UEFI)
                Processor: 11th Gen Intel(R) Core(TM) i5-11400F @ 2.60GHz (12 CPUs), ~2.6GHz
                   Memory: 16384MB RAM
      Available OS Memory: 16282MB RAM
                Page File: 28176MB used, 5284MB available
              Windows Dir: C:\Windows
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
 DirectX Database Version: 1.0.8
           DxDiag Version: 10.00.19041.5794 64bit Unicode
       Card name: NVIDIA GeForce RTX 4080
        Manufacturer: NVIDIA
           Chip type: NVIDIA GeForce RTX 4080
            DAC type: Integrated RAMDAC
         Device Type: Full Device (POST)
          Device Key: Enum\PCI\VEN_10DE&DEV_2704&SUBSYS_51121462&REV_A1
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 24190 MB
    Dedicated Memory: 16050 MB
       Shared Memory: 8140 MB
        Current Mode: 1920 x 1080 (32 bit) (60Hz)
         HDR Support: Not Supported
I have tried the following:
Installing the latest Nvidia Game ready drivers
Installing the latest Nvidia Studio drivers
Reinstalling Daz 4.24
Reinstalling Daz 6
None of this has worked at all. It's pretty demoralising. It's like a 'no daz for you' switch has been flicked.
  • garrett_3dgarrett_3d Posts: 1,029
    Looking at the log, there are two textures missing. You may want to use DIM to uninstall and reinstall G9 base and Michael 9.
  • crosswindcrosswind Posts: 10,341
    edited June 10
    You can try:
    1stly, uncheck CPU in Render Settings pane > Hardware tab > Photoreal mode - Devices (i.e. only Iray render with GPU),  then Ctrl + 0 to NVIDIA Iray previce, see if DS crashes.
    If DS still crashes, uncheck, RTX 4080, only render with CPU, see what'll happen...
    Besides, when you preview / render with a newly-installed Nvidia driver for the first time, it'll take some time for DS to prepare / compile the engine, so you have to wait for a while before getting the preview in Viewport...(appr. 30 secs to 1 min ~~)
    Post edited by crosswind on
