Can't load G8 Figures Since Installing Daz 6
AbrahamRockwellAbrahamRockwell Posts: 155
edited June 9 in Daz Studio Discussion
As the title says, ever since I installed Daz 6, I can't load a G8 figure anymore, I just get the error message in the attachment.
I don't know ehy its doing this.  I even went back and reinstalled G8 Essentials, first in my 'base' runtime, then in a different one, but I still get this error.
Luckily I had saved versions of the base models, so I can load them with no problem (and it does load G9, but I will have to check for G1 -G3).
Anyone else having this problem, and have a fix for it (I also uninstalled Daz 6 [more trouble then its worth], but still get this error)
1920 x 1000 - 168K
Post edited by AbrahamRockwell on
  • felisfelis Posts: 6,560
    edited June 9
    If you open the path in file explorer, how does it then look?
    Can you load a non-base G8F character?
    And you haven't changed the path of your content?
    Post edited by felis on
  • LeanaLeana Posts: 13,585
    Did you setup the content directories in DS6 preferences? It has its own set of preferences and doesn't copy them from DS4 settings.
  • barbultbarbult Posts: 27,608
    The screenshot is of DS4.
    Oh right I missed that. As they mentioned installing DS6 I assumed it was where the problem was.
  • AbrahamRockwellAbrahamRockwell Posts: 155
    Thanks for the answers, all.
    I'll go back and check to make sure all my Runtimes are included properly.
    As I said, though, I can load every previous model except G8 with no problem (all using the same Runtime, so I don't see why that would be a problem).
    And it all started after I installed Daz 6, I even uninstalled D6 and tried again, but no luck.
