Objects change position after drag and drop to be parented
tam_c3df5332fctam_c3df5332fc Posts: 147
edited June 4 in Daz Studio Discussion
Hey everyone,
This started happening to me only recently version 4.20 Windows 11
I have saved a preset for a set of lights - five - two in front and three behind - BTW, I can import an object and the same thing will happen that I am about to describe, so please do not focus on the five lights
After whatever object I select, drag & drop to be parented onto the hip of the character so that it can follow it around (please do not focus on drag & drop to the hip because this happens if drag & drop the objects to be parented onto the head or any other part of the character's body)
What happens at this point is the object(s) will suddenly dramatically change positions - see attached screenshots - the lights went from where they are supposed to be, to all the way out of the scene
Why did this just start happening without performing an update or installing anything new?
Is there some setting that I have accidentally switched on? Do I have be in a certain tool set before trying to parent an object to a character
Thanks in advance
2796 x 1941 - 800K
2786 x 1853 - 782K
Post edited by tam_c3df5332fc on
  • frank0314frank0314 Posts: 15,114
    Can you please attach your log in a text file and attach it to a post so we can look and see if anything is out of place?
  • garrett_3dgarrett_3d Posts: 1,038
    Not something I've experienced myself so I can only guess. Maybe DoF settings or something like that? The way my logical brain works suggests that if DoF is somehow parenting in a priority status, it will move the lights/cameras to suit. Just a thought.
  • thoreandanthoreandan Posts: 152
    Is it possible the "parent object in place" setting got unselected? It's in the hamburger menu under "Parenting". This setting used to be in a more prominent place, but now it's buried.
  • tam_c3df5332fctam_c3df5332fc Posts: 147
    Thank you so much @thoreandan
    That was it. Somehow it became unselected, now everything works as expect - thank you thank you thank you
    424 x 768 - 34K
