Utility to help with applying new texture maps
DeeceyDeecey Posts: 200
On the Poser side, I use Dimension 3D's Poser File Editor to easily make changes to reassign textures to a character. However, I can't seem to find something similar on the DAZ side, and I find the surface editor to be really cumbersome to use.
Is there something available anywhere that would be easier to use?  Thanks in advance.
  • DeeceyDeecey Posts: 200
    Oops I may have just answered my own question. Found this ....
    https://www.daz3d.com/map-manager
    Maybe not. It doesn't support Genesis 9. Any other ideas?
  • lilweeplilweep Posts: 2,879
    • You could save out a mat preset and then use a text editor to find/replace the specific file/folders
    • You probably already know this, but you can drag/drop maps into the Surfaces tab onto the channels, which if you didnt know may speed up process
  • WolfwoodWolfwood Posts: 998
    It doesn't? Gen 9 is certainly in the list of compatible figures.
    Yeah that's what I thought. I'll check with support
  • LeanaLeana Posts: 13,621
    edited June 1
    It’s listed as supported in product description too.
    edit: according to the readme it was updated to support G9 in 2022
    Post edited by Leana on
    edited June 1
    Yeah I'm looking into it now. My old brain doesn't work as well as it used to, and I'm having a hard time following the docs. The last year in particular has been bad for memory. Time to see the doc. That's why I decided to retire from writing documentation. LOL
    But yes, I see that it does now support G9.
    Post edited by Deecey on
  • ElorElor Posts: 4,223
    In case you have other problems, there is a commercial thread monitored by V3Digitimes:
    https://www.daz3d.com/forums/discussion/226176/released-map-manager-commercial
    Oooh thanks for that.
