Where has Geometry Sculpture gone?
Have loaded the latest 4.24 and this never loads online or offline and being Premier I should have it?
  • Richard HaseltineRichard Haseltine Posts: 111,157
    It dos require instalaltion, but if you have it installed and the application says it is Daz Studio Premier in the title bar then yes, it should be there. It does need to match the DS version too - check help>About Installed Plug-ins to see if there are any issues.
  • rhye_7b205b2b74rhye_7b205b2b74 Posts: 122
    Thanks, how do you get rid of the start where it keeps looking for Reality?
    What is looking? Do you have reality installed and it isn't working correctly, or is this a DS or a scene complaining that it can't find it? Please post a screenshot of the error pop-up, or the text of the log entries, or both.
    edited May 27
    It is DS loading and telling me it cannot find Reality and then opens up the folder I guess it should be in
    689 x 556 - 55K
    Post edited by rhye_7b205b2b74 on
    Sounds like a setting that is pointing to Reality but not finding it there (or it isn't working). Do you have it? Is it installed? Does it appear in Help>About Installed Plug-ins?
    Well that message never appeared before I updated it, and I have no idea where Reality actually is?
    Reality is/was a separate plug-in that was available to enable the use of Lux Render with DS (and had versions for Poser and Carrara too, I think).
    Thanks for your help, seems as though it is looking for a different dll, as the plugin points to the file in help and it contains Reality_DS64.dll, so just need to know what actual dll it wants.
    Do you have Reality installed? What is this plug-in pointing to the file in help?
    Not sure, never used it before, I'll try disabling it in plugins that might get rid of the messages
