3D print issue
leo04leo04 Posts: 414
I have a prop, which has a door in it. The Door is a "bone" so when I export this prop to an .obj fle it has a open space in it.
I want to take this door and make it into a solid part of the entire prop.so when I export it I can print it with the rest of the prop.
Any ideas on how to do this?
Thanks.
Post edited by leo04 on
  • Richard HaseltineRichard Haseltine Posts: 111,929
    That sounds like a job for a dedicated modeller. If UVs don't matter you can probably just cut out the front face of the door and the frame and then use the tools in the modeller to patch/bridge them together; if UVs do matter then make sure you use an application that won't destroy them in that kind of edit.
