Limbstick G8M typeerror?
Not sure what is going on but 3D Universes Limbstick for G8 has been working fine since first installed but now is producing errors.
According to the log typerror?
2026-05-21 21:48:06.973 [WARNING] :: Script Error (D:/Users/Public/Public Documents/DazExternal/Scripts/3D Universe/Limb Stick/3DU LimbStick G3+8.dse): Line 1095
2026-05-21 21:48:06.974 [WARNING] :: TypeError: Type error
2026-05-21 21:48:06.974 [WARNING] :: Error in script execution: D:/Users/Public/Public Documents/DazExternal/Scripts/3D Universe/Limb Stick/3DU LimbStick G3+8.dse
2026-05-21 21:48:15.039 [INFO] :: Closing main window...
I uninstalled and then re-installed Limstick but no change.
I cant figure thus out it has been working fine for years.
  • MouserMouser Posts: 775
    Okay I figured maybe the old v4 of DS was the issue so I
    >Uninstalled v4
    >Deleted v4 folder
    >Removed v4 from the DIM instalation paths so now there is only the 2026 public build listed as a download.
    >Re-installed limbstick.
    Same issue?
    Okay nothing is working with G8 with Limbstick so I tried G9 instead, same result.
    Looked back in the DIM and it has put the DS v4 install paths back in despite me removing them.
    Despite this there is only one version of DS the 2026 build installed but as the DIM ignores anything I input regarding install paths I am unsure what is going on.
    Please has anyone run into this as I am at a standstill?
    Okay here we go again.
    Manualy downloaded limbstick (both versions G8 & G9)
    unpacked and installed in the my library folder on the C drive so the public build should have no issue accessing it.
    Same result.
    Q: has anyone been able to get Limbstick to work with the 2026 public build?
    Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,947
    It may well not work with DS 2026, the error message suggests that the type of a data item is not the same as it was in older versions (types being things like numbers, strings, and also all the DS-specific things like figures, nodes, UIU elements and so on). C an you not use it in DS 4 and then send the result over to DS 2026 for rendering?
    Unfortunatly my new machine has a 5060 graphics chip and it doesnt render Iray on the DS v4x.
  • felisfelis Posts: 6,625
    That is why Richard suggested you do the scene in DS4 and save it, and load it in DS6 and render.
    Yes kind of like having to us DS32 for the old mimic lypsync, save then hop onto the DS64 to finish.
    Clunky but workable, I'll be gald when 2026 becomes a standard release.
    Okay uninstalled the public beta  & installed DS6 but limbstick still not working.
    I can use the DS 2.4 save it and run in DS 6 same as the beta but this is not a real solution.
    Heres hoping for some product updates.
