DAZ3D option to export Iray materials to PBR industry standard
kenmokenmo Posts: 1,206
edited May 21 in Product Suggestions
I would like to suggest an option to export DAZ Props with Iray materials converted to PBR industry standard.
Many of us do not have the mega bucks to purchase a newer Nvidia RTX video card and would like to export our scenes to Vue and other render engines.
Vue does not like Iray materials. Exporting to PBR would open up a world of opportunity to exchange our scenes and props with other 3D apps we are using.
If DAZ upgrades continue to demand we upgrade to very expensive Nvidia gpus in this time of economic stress for most everyone in North America and elsewhere, this fantastic hobby will be too expensive for hobbyists and perhaps rightfully go the way of Studbaker cars and beta machines.
Cheers
Kenmo
PS: And please do not tell me it can not be done. Anything can be done if given the proper attention and resources.
Post edited by kenmo on
  • Richard HaseltineRichard Haseltine Posts: 110,877
    What do you mean by PBR? As a term it just means physically based rendering, and Iray is a PBR engine, so it isn't clear. Nor is it universally true that everything is possible through an automated process, which is what you are asking for, without user input of some kind.
  • garrett_3dgarrett_3d Posts: 635
    I thought the PBR was the river boat used in the Vietnam war by the Americans....
  • kenmokenmo Posts: 1,206
    PBR  materials - Physical Based Rendering Materials.
    What is PBR
    https://en.wikipedia.org/wiki/Physically_based_renderinghttps://en.wikipedia.org/wiki/Physically_based_rendering
    Free PBR materials
    https://freepbr.com/
    https://ambientcg.com/
    https://www.poliigon.com/textures
    Quoting poligon link above "PBR textures for Blender, 3ds max, Cinema 4D, Sketchup, Unreal Engine, Unity and Maya. Complete PBR texture sets that are perfect for creating archviz, vfx, games, animation and product visualization."
    PBR explained
    True, but it does not follow the industry PBR standard. IRAY materials can only be used in Iray and not shared with Vue, Unity, Unreal, etc. PBR standard materials I use and create in 3D Coat can be freely shared between  Blender, Vue and DAZ. But any materials created for DAZ Iray can not be exported to an industry standard PBR format which can be shared with 3DCoat, Vue, etc.
    There are two industry standards for PBR Metalness/Roughness and Specular/Glossiness. It appears Metalness/Roughness is the most used.
    edited May 19
    Key components of PBR materials. Daz is using a propietary version of PBR which can only be used by Iray.
    https://lightbeans.com/en/blog/tutorials/pbr-physically-based-rendering-explained-a-quick-guide
    A great free utility I often use to assist in the creation of industry standard PBR materials.
    https://www.boundingboxsoftware.com/materialize/
    But again, Iray is a PBR engine. One potential issue is in the normal maps - there are two standards so it is possible that your other applications are, at least by default, usiing the other standard and so lookiing wrong.
    I know that. However when I export an DAZ Iray prop as an obj (ie: prop.obj) with supporting .mat file (prop.mat) and material/texture files (diffuse.jpg, bump.jp, normal.jpg, displacement.jpg, etc). If I import the prop.obj into Vue, 3DCoat, Modo, Blender, etc. Many of the material/textures files are not recognized or missing.
    If I export a prop from Vue, 3DCoat, Blender with supporting texture/material files. It will load flawlessly into DAZ, Blender, Vue, 3D coat and the model will be properly textured.
    I think the issue is DAZ does not properly export Iray shaders or can not.
    The OBJ MTL file is very limited, are you using that format with the other applications too? It sounds as if your request is for a format that better supports material settings, though I wouldn't try OBJ as a starting point now.
    What format would YOU recommend that interchanges between Vue, DAZ, 3D Coat, Blender and sometime Hexagon?
    I've tried DAE and FBX and ALWAYS have issues with both formats. GLTF/GLB are not recognized by DAZ, Vue or Hexagon.
    The only format that does not destroy the topography is OBJ for me but texturings can be uncertain at times when I export from DAZ/Iray.
    I do not have the same issues when I export from 3DCoat or Blender.
    So once again since YOU suggest a different 3D file format, kindly recommend one that works between Vue, DAZ, 3D Coat, Blender and possibly Hexagon.
    Thanks kindly and I eagerly await YOUR answer since YOU seem to believe my product suggestion is not a good idea.
    Kenmo
    I haven't tried moving anything but geometry, which is why I didn't offer a specific suggestion.
  • felisfelis Posts: 6,421
    I don't think any of the supported formats are good at preserving materials. So after transferring your objects, you might have to apply materials manually.
    Another option is the use Diffeo to get it into blender, and then export in Universal Scene Description format, if your target application supports that.
  • lilweeplilweep Posts: 2,841
    DAE and FBX formats are not Daz to VUE bridge, nor Daz to 3D Coat Bridge, nor DAZ to Blender Bridge nor Daz to Hexagon bridge.
    If you want GLTF/GLB then go Diffeomorphic -> Blender - > GLTF/GLB
    It seems kind of bizarre to need a consistent shader between all these different software. You only need to do final look development in your FINAL RENDERER.
    topography?
    Correct OBJ is not a bridge.
    If you want all the texture files, go to their folder location and use them from there or use Diffeomorphic -> Blender in your workflow.
    I think you will also have similar limitations and you just havent noticed.
    3DCoat does not support the complexities of Blender's shader mixer, so if you are just doing a basic PBR textures in 3DCoat, sure, it might look similar, but it is not robust.
    Vue, DAZ, 3D Coat, Blender, Hexagon is kind of absurd.
    You do not need to have a functioning material in anything but your final renderer.  Even in 3DCoat it is not necessary to have it look like your final renderer when doing texture painting and material set up.
    It is honestly pointless to develop a comprehensive end to end workflow that works perfectly for all these applications anyway in a 1-to-1 way where they look the same in each application.
    Why do you even need a functioning material in Hexagon of all places???
    Kenmo
    I use Vue and DAZ for rendering.
    Of course I mean topography!
    edited May 21
    Of course I mean topology! Sorry about the typo. Just recently rleased from hospital and still a little under the weather.
    I like to render in Vue and use DAZ assets as I believe they are superior to props created for Vue. Since most DAZ items now use iRay materials and Vue does not support Iray but supports the two industry PBR standards (metal/roughness and specular/glossiness). Please make this option happen.
    Look at the Surfaces pane in DS - the Iray Uber base already does that. Your issue is not the materials but finding a route to export the settings.
    edited June 23
    BINGOI! and that is the title of my thread "DAZ3D option to export Iray materials to PBR industry standard". Thanks Richard, I am glad we are finally on the same wave length.
    Maybe next time you are sitting around the table with the DAZ product developers you can push for my export option.
    Cheers and many thanks.
    Kenmo
