Last Days dForce Clothing for Genesis 9 (Long Shirt)
I see why it was released a day before Iray Rips and Tears. I often a bit like I'm playing a shell game with Daz, but this is quite the insult added to injury. Not only did Last Days cost me more, but Rips and Tears is more versitile. I find myself... torn with the idea of returning Last Days. I rarely if ever return products.
  • HavosHavos Posts: 5,705
    You are not really comparing like with like. Last days has the rips in the geometry, where are Rips and Tears uses opacity maps to create the holes. The latter method looks ok from a distance, but up close the rips do not look that realistic. Last days will look good even zoomed in. $30 seems quite a high base price for just a T-shirt, but you have to look at the effort that went into that single garment to make it look like it had seen much better times. Tears that look realistic even up close are not easy to do.
  • DareshiranuDareshiranu Posts: 338
    Okay, I'll grant you the difference. But the similarities between the two are still somewhat obvious depending upon your use case.
  • xyer0xyer0 Posts: 6,518
    I want both!
