Trying To Use A Photographic Background – Not A DAZ Backdrop – For A Tower Scene
I’ve been at this for about six weeks now, scouring the internet for tips and techniques, but definitive counsel has been vanishingly thin.
I’m trying to take a sequence of renders set atop a tower.
The fact that you have a view of the surrounding area from the top of the tower – at least in the initial render -- is a story point.
Normally, one would use the DAZ Backdrop feature for something like this, but while this is perfect for a single render, the fact that Backdrops instantly re-align themselves whenever you move the active camera makes them unusable for a series of renders taken from different angles.
For those who don’t know what I mean: if your initial Backdrop shot from the tower set shows a mountain in the distance straight ahead (north), the beginnings of a forest to the left (west), and a shoreline to the right (east), as soon as you move your starting camera, or switch to a new camera angle, the Backdrop image will realign itself to the new angle.
If you shoot left (west), for example, the mountain will now be centred on the left; the shoreline will be to the north, and so on.
Basically, DAZ Backgrounds can be great for realistic looking one-off renders, but they don’t work if you’re shooting a series of renders around your set.
I also tried making an HDR skydome backdrop, but the HDR process also wanted to incorporate the top of the tower itself (the “ground” for the characters in the scene) into the HDR, which created problems and limitations when moving the characters around the set, or setting up basic interactions between the characters atop the tower, or the objects on that set.
Recently, I’ve been chasing a more “old school” DAZ solution – trying to setup large primitives (rectangular shapes) around the set and basically attaching high-quality background images to them so that the surroundings of the set look plausible from inside the scene.
Unfortunately, properly creating such primitives within DAZ, and then “attaching” the images to these primitives is not spelled out anywhere I’ve been able to find.
I’ve tried to study certain DAZ assets which use high-quality photos on primitives for backgrounds, but I’m obviously missing some crucial details of the process, because the images never look as intended when implemented by me, if they’re even visible at all. I’ve adjusted and experimented, but nothing seems to work as intended.
So, thank you to anyone who’s actually read this far, and if someone has any thoughts on how to acquire the desired results, I’d be grateful to hear them.
Any sort of workable solution to this problem will have my gratitude. Cheers!
  • felisfelis Posts: 6,525
    A picture of what you are experiencing might help the understanding.
    But for a plane with an image, you must ensure that the size of the plane matches the image relatively. And after you have added the image in Base Color, you also want to add it to Emission (set color to white) with a moderate to low value in Luminance/Luminance Unit, e.g. 10-30 kcdl/m2 (I can't remember a good value), and adjust as needed.
  • jmucchiellojmucchiello Posts: 2,149
    I find leaving the plane square and modifying the h scale and v scale in geometry easier. Even if the image wraps on the plane, the plane should be placed such that the edge of the image isn't seen.
  • garrett_3dgarrett_3d Posts: 901
    I don't have this issue with either backgrounds or skydomes - they stay exactly where I put them. Do you have them parented to your camera?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,574
    edited May 10
    you need a cyclorama shaped like a bowl or half bowl
    I made my own from a sphere flattened on the base spherically UV mapped for panoramic images but a half one could take wide angle images
    there are cycloramas in the store but most are just curved planes
    the Millenium environment is somewhat like I described but has a separate terrain base
    https://www.daz3d.com/millennium-environment
    you can load your own wide images (photos or renders) on it and add cutout opacity maps (using an image editor to make sky black and rest white if photos)
    I use it surprisingly a lot
    A dFormer can easily curve a plane.
  • mysecretidmysecretid Posts: 15
    Genuine thanks to everyone who responded to my initial post! I'm truly grateful for all the kind help.
    In the days since I first posted, I managed to put together an "old-school" style background consisting of the photographic background image attached to a rectangular plane. Unfortunately, it suffers from the very problem which made renderers move away from that type of solution and toward HDR skydome solutions -- it just doesn't look convincing enough when all is said and done.
    With work and postwork, the set could look passable enough in a single render from a single angle -- but since I need to shoot a full scene, from different angles, it reads as false fairly quickly. The light, in particular, just does not match convincingly between the set and the surroundings across a series of shots.
    I think I'm going to have to look again at creating an HDR skydome environment around the tower set. Maybe if I modify my approach, I can get that to work this time?
    The only other solution I can think of at this point is to shoot the entire render sequence with transparent backgrounds to the renders, and then (somehow) try to add in convincing backgrounds with postwork background shots merged through Affinity Photo. My postwork skills are not professional-grade, more like "ardent amateur", but I'm running out of options to create this necessary story section, and I've already lost six weeks trying to solve this unexpected difficulty. Wish me luck!
    I'll answer each of the people who took the time to answer me specifically below. Again, I do appreciate everyone here who reached out to help. Thank you!
    Thanks! I didn't attach a picture simply because nothing I've implemented beyond using DAZ Studio's "Backdrop" feature has even remotely worked as intended, and the tower-top set is simply a standard DAZ set against the default grey void of DAZ. There's "nothing to see here" as the saying goes, and that's sort of the problem. :-) I tried the "image on a plane" as you suggested (thank you!) but it didn't look realistic enough across a series of shots and angles. I think my only way left to go forward is to try again to create an HDR skydome for the surroundings, that I can then use in the tower scene. We'll see how that goes. Be well!
    Thank you! As above, I found that using background planes mounting a photographic image just didn't look plausible across a series of renders taken from different angles. The light in the images always looked false on some level, even when tweaked. I imagine this is why DAZ renderers generally moved on to HDR skydomes for backgrounds in multi-image scenes, but it could certainly be a failure of my own skill level. I can only do what I can do, however, but I do absolutely appreciate your counsel in my search for a solution. Cheers!
    Thanks, Garrett! I suspect we're talking about two different kinds of background/backdrop in DAZ3D here.
    When I was talking about a Backdrop (capital B) in my scene, I was referring to the Backdrop feature in DAZ Studio, specifically, not just a standard background. It's kind of a hidden feature.
    If go to the Environment tab of the Scene section of your scene in DAZ (i.e. not the Render Settings section) you'll see a drop-down at the top that you can toggle which reads None initially. If you click the toggle, you'll see a choice which reads Backdrop. You can select a picture from your drive and drop it into that slot by clicking on the left spot.
    This chosen picture will then become a background image for your entire scene, so long as you have iRay switched on.
    The problem (in my case) is that this Backdrop image instantly reorients itself to whichever direction your active camera in pointing at the moment. There's no parenting involved, it's simply how the Backdrop feature seems to work.
    The irony, in my case, is that the Backdrop feature works pretty much perfectly for my scene, except that I need to shoot from more than one camera angle, which breaks the illusion, because the same view is shown in every direction.
    Thank you for trying to help me out. It is very much appreciated. Be well!
    I often save my camera sequences to render the backgrounds separately afterwards
    Ultrascatter and lots of planes with images of foliage with matching cutout opacity go a long way in filling out a background, there are plenty of those in my library including from the named Millennium Environment addon textures , open cylinders with transparency mapped hills, Stonemasons backgrounds from his sets
    Thank you for your suggestions! As above, I didn't have much luck with attaching a photograph to a primitive plane, in that the image never looked convincing enough, lighting-wise, no matter how I tweaked the lights/emission, or how I shot it.
    I expect that a cyclorama, or a similarly curved shape, might be better for realism, but I freely admit I'm not good at working with shaping primitives in DAZ, so I will probably have to go another route. I did look for ready-made "shaped" cycloramas for DAZ online, at your suggestion, but couldn't find much on offer that I could tweak for the needs of my specific scene.
    I think, for now, I'm going to have to look at trying to create an HDR skydome enronment for my scene which captures the sky and surroundings, but which leaves my tower-top set alone. Here's hoping I'm up to the task! :-)
    Thank you for offering your help. It's definitely appreciated!
    Thank you again, but I must confess, I'm currently terrible at working with dFormers. I understand the theory of how to use them, but I'm embarrassingly bad at implementing them. No talent for the tools, I guess. Thanks anyway!
    finite dome keeps it relative to camera movement
    Hidden - that's why I've not found it yet.
    Toddles off to check.....
    Just tried it with a random background photo of my track bike. In perspective view or camera view, it rotates everything added to the scene around on the central axis. The background itself remains static and the view of it never changes.
    I suspect what you may need to do is use a backdrop prop with custom image, which is what I assumed you meant initially.
    Thanks for the reply! What you're seeing, and what I've been seeing, seem different, and I can't seem to suss out why on this end. As before, if I slot an image into the scene Backdrop spot, that image looks perfect -- until I change the camera direction, whereupon the Backdrop image will instantly realign to whichever direction the camera is currently facing. The distant mountain due north will now appear due east, if that's the way the camera is now facing (no parenting involved).
    I appreciate you taking an extra look on my behalf, as you did, but whatever's going on, I'll have to find another way to shoot the scene. I've already lost almost two months now trying to sort this. I think I need to finsd a different process. Be well, and thanks again.
    So where in my case everything oriented with the camera, in your case it's just the backdrop that orients with the camera and everything else stays still?
  • Jan_ScrapperJan_Scrapper Posts: 798
    edited May 20
    I just used this:
    Daz3D Backdrop Tutorial [2024] - RenderGuide.com
    It is wonderful!!
    You are more than welcome to use my scene!  I made it in ChatGPT :)
    1448 x 1086 - 3M
    2549 x 1370 - 464K
    Post edited by Jan_Scrapper on
    WendyLuvsCatz said:
    finite dome keeps it relative to camera movement .
    Thank you for the suggestion, Wendy Friend Of Cats :-)
    I did try to implement your suggestion, but alas, finite dome didn't actually keep my Backdrop image fixed relative to my camera view(s). If I knew why it didn't work, I suspect I wouldn't be having this problem in the first place. In other words, I know whatever's going wrong here is some lack of knowledge and/or skill on my part, and I am grateful for you and all the other posters who have freely offeried help. Be well, and thanks again!
    Jan_Scrapper said:
    I just used this:
    It is wonderful!!
    You are more than welcom to use my scene!  I made it in ChatGPT :)
    Ah! Thanks for jumping in, Jan! I'll take a closer look at what you posted and see if it leads to any answers for my scene problem. It may take me a few days to report back, but I'll let you know once I know. Be well!
    Yup. Maybe that's how Backdrop images slotted into DAZ3D's scene Environment tab are intended to work? You know, because (I suspect) most DAZ users are simply creating one-off image renders anyway, not a sequence of images where the background has to stay plausibly consistent, like in a storyboard or graphic novel, the way I'm doing. Entirely possible.
    I'm going to continue looking for other ways people have solved the "how to create a convincing photoreal backdrop" problem -- and in the meantime, I'll likely spend more tiime on other parts of the project. At six weeks plus, I've burned too much time on this scene setup already, and living in frustration is not good for anyone. :-)
    Thanks again for all your attempts to help solve this issue for me. It's appreciated. Be well!
  • chris-2599934chris-2599934 Posts: 1,979
    Here are a few possible approaches you could try...
    Do the whole thing with real geometry. There are large low poly landscape products out there, e.g. Medieval Lands, or others that let you build them like Ultrascenery XT. Terradome 3 is another possibility if your tower is surrounded by not-too-distant mountains.
    Do the nearby terrain with real geometry, and the distant stuff with billboards. This works well at ground level, maybe less so from a tower. I use a cylinder primitive created without caps, with a seamless background image for opacity and diffuse. This can work well for distant hills on the far horizon, may not be so convincing closer to the camera. Lighting can be problematic too.
    Make an HDRI. You said "I also tried making an HDR skydome backdrop, but the HDR process also wanted to incorporate the top of the tower itself." The answer to that is simple: don't include the tower when creating the hdri. Just have your camera floating in space where the top of the tower is going to be and make your hdri (presumably using some real geometry as set out above). Then you can use the real tower combined with the hdri background.
    Use an existing hdri. There are some that are done from high places. Green Hills springs to mind. You might find something on a free hdri site that would work, again possibly by having real geometry close to the tower and using the hdri for the distance. If you're doing that, it helps if you have something solid - a wall, a line of trees, a hedge - to cover the join. So everythin inside the wall is real and outside is hdri.
    The one thing I would not do is attempt to use the photographic background in the Environment tab to do this.
    I just saw this reply now, Chris. Thanks for taking the time to answer at length; it's appreciated.
    I haven't had much luck solving the process thus far, and I may well have to work with one of the more complex solutions you decribe. I'm nervous of getting out ahead of my competence zone, however. I'll see how I do with creating an HDRI backdrop with a floating camera as you suggest, but it may take a while before I can manage something passable. My DAZ skills are decent, but I wasn't born rendering. :-)
    With the arrival of DAZ 6 creating havoc for users currently, I expect to stay with DAZ 4.xx until the fire and the smoke dies down. The last thing I need on this project right now is the tools and techniques I *do* know changing out from under me.
    If I do ever solve this conundrum, I'll come back here and tell the tale. Thanks again for the reply. Be well, go safely!
