IG Iray Dawn to Dusk
Hi everyone. I have been able to use [IG Iray Dawn to Dusk] this item for some time (years). At some point it just stoped working. I used to use it all the time with its abbility to place the sun anywere in the sky and presets for dusk to dawn intecity. I have tryed to replace it but have found nothing as good. Reloading it didn't solve the issue. I just get a message stating that Daz incountered an error. I see a Dawn to Dusk 2 that is still available, but don't think it's the same thing.
  • Richard HaseltineRichard Haseltine Posts: 111,475
    Moved to Techncial help as it is a product, rather than a Daz Studio application, topic.
    This https://www.daz3d.com/ig-iray-dawn-to-dusk-2-atmospheric-lighting ? Did you check the end of the log file (Help>Troubleshooting>View Log File) just after trying to use the presets? It sounds as if you may be using a preset of some kind without anything selected for it to work on, though pure render settings shouldn't need a node. You may want to make sure you have the Environment and Tone Mapper Settings nodes in the Scene - either from the Create menu, or start an Iray render and then cancel it.
