Gen 2 Base Male to Base Female Converter
Not sure if anybody know's but I'm looking for an app or method to quickly convert Gen 2 Male base textures to Female base textures and vice versa. Anybody got anything?
  • HavosHavos Posts: 5,692
    Is this to use G2M skins on G2F figures? If yes, then you do not need to convert them at all, just copy the relevant male UVs into the female data, and all male skins can be used on the female figures.
  • Tyber14Tyber14 Posts: 3
    So the seams and everything will match up? Feel like I tried that before but the they didn't want to match up properly but I haven't tried it in a long time so I could be wrong.
    Thanks for the heads up.
    Should work perfectly. G2M and G2F are the same mesh, they just have a different default morph. (Weight mapping is also different of course, but that would not effect the UV mapping).
    Of course geografts might have issues, if the female ones are different to the male ones.
  • JOdelJOdel Posts: 6,322
    G3 figures have slightly different meshes though.
