How to Set Shader in DazScript?
I've cobbled together some informal DazScript to find the shader name for each surface selected (see attached). Now, how do I set the shader to a new value for the selected surfaces? For instance, how do I change the shader from "Iray Uber" to "DAZ Studio Default" or vice versa? Thanks in advance for any help!
--John
        sel = Scene.getPrimarySelection()
        var oObj = sel.getObject();
        var oShape = oObj.getCurrentShape();
        var aMaterials = oShape.getAllSelectedMaterials();
        if( aMaterials.length < 1 ){
            aMaterials = oShape.getAllMaterials();
        alen= aMaterials.length;
        for( i=0 ; i<alen ; i++ ){
            mat = aMaterials[i];
            debug( "mat:", i, "--", mat.getName(), "--", mat.getMaterialName() )
  • Thank you, Richard -- promising example. I'll update once I've played with the script some.
  • edited May 3
    Thank you for the assistance, Richard. The script didn't directly fit what I needed, but playing with it did lead me to a solution, that I'll share here in case it helps anyone searching the forum later.
    The reason I wanted to set the shader myself in code was so I could do a better job handling opacity maps, especially when doing image masks to identify which pixels of the output image came from which figures/surfaces in the scene.
    So two use cases:
    • 1. using the dzDefault shader (content:/Shader Presets/DS Defaults/dzDefault) often loses opacity maps when applied (I'm guessing because iray mats use a different property name for opacity);
    • 2. and I often use geomshells when constructing masks, and it can be useful to copy over opacity maps to the mask
    Below are 2 informal DAZ script functions and a third debugging function while I tested them.
        getDictOpa = function getDictOpa(){
                if( aMaterials.length < 1 ){ aMaterials = oShape.getAllMaterials(); }
            var dictOpa = [];
                key= mat.getName()
                opa= mat.getOpacityMap();
                dictOpa[ key ] = opa;
            return dictOpa
        setDictOpa = function setDictOpa( dictOpa ){
                key = mat.getName();
                mat.setOpacityMap( dictOpa[key] );
        dumpDictOpa = function dumpDictOpa( dictOpa ){
            for( var key in dictOpa ){
                if( key=="pushIfNotExists" ) continue;  // hack
                if( key=="find" ) continue;  // hack
                if( key=="findValue" ) continue;  // hack
                debug( "dumpdict:", key, "--", dictOpa[key] );
        Usage:
            - select figure and optionally surfaces (if no surfaces selected, all are used)
            - run this in Script IDE window:
                tempopa = getDictOpa()
            - select the figure you want to copy the opacity maps to
            - run this in the Script IDE window:
                setDictOpa( tempopa );
            - it applies the copied opacity maps by surface name
    These don't directly set the shader like I originally asked (it looked a little hairy assembling a full shader from scratch to apply), but they are workarounds that get the job done -- which is generally good enough smiley
    Post edited by bluelake_2cfb0bd048 on
  • Richard HaseltineRichard Haseltine Posts: 111,217
    I thought the name used  to match, but certainly in DS 6 it now shows as name = Cutout Opacity. I may have been thinking of something else, or it may have been modified (which seems fairly unlikely).
