Discovering the limits
Hi all,
I am still quite new to DAZ (using the new beta version) and on one of the sales I got this environment:
https://www.daz3d.com/pw-millionaire-mansion
I have 32 gb RAM and 5080 16 gb and when the environment loads it immediately horribly lags. is it just that 16 gb vram 5080 is not enough for such a big map or is it my settings not being set up properly? Is there any chance of using it in addition with several figures and some props or is 5080 simply not enough for the task? Wondering if I went past the limit for my GPU.
Cheers,
  • Richard HaseltineRichard Haseltine Posts: 111,642
    Are you using Iray Drawstyle to preview? That could be quite demanding, though (without owning the product) I would have expected a 16GB to cope; on the other hand, 32 GB of system RAM to feed that is limiting, iit may well be that some disc-swapping is going on as the data is sent across to the GPU.
  • crosswindcrosswind Posts: 10,313
    The spec. of your RAM / VRAM looks fine... but if you mean with DS 6.x Public Build.... the loading time of this scene on my side is appr. 35 seconds which is faster than DS 4.24. but manipulation with the whole scene in Viewport in Texture Shaded drawstyle is slower (not really laggy) than DS 4.24.
    So what do you mean by "horrible lag", when you manipulate the whole scene in DS Viewport with Texture Shaded drawstyle ?
