Solved Material bleached in Daz Studio 2026
artsinis.sanartsinis.san Posts: 16
edited March 25 in Daz Studio Discussion
Hi,
I was using this texture/material option: https://www.daz3d.com/dforce-ethereal-fantasy-outfit-textures
I rendered the same file in Daz Studio 4.24 and Daz Studio 2026 and the 2026's version came out bleached. Any ideas why that is and what I need to change to get the same quality in the Daz 2026 version?
1920 x 1080 - 3M
1920 x 1080 - 3M
Post edited by artsinis.san on
  • StonemasonStonemason Posts: 1,280
    if you select the Base Color texture in Surface Editor and then open Image Editor, if Image Gamma is set to 1 instead of 0 then that might be the problem, setting it to 0 will fix the issue.
    I have no idea why DS does this, it seems very random
  • Richard HaseltineRichard Haseltine Posts: 111,878
    Are you sure you are using the Iray materials, not the 3Delight materials?
  • if you select the Base Color texture in Surface Editor and then open Image Editor, if Image Gamma is set to 1 instead of 0 then that might be the problem, setting it to 0 will fix the issue.
    It was 0, but this is awesome! I never knew gamma could be set that way. Thanks, today I learned. ^^
    That was it. I trusted the mdl material blindly, because I read somewhere that mdl is iray. Looked very iray in the viewport in 4.24, too. Now I clicked on "browse to file location" to confirm and landed in the 3Delight folder while the rsl material lead to the iray folder. Urgh, do I feel stupid. Thanks for helping out an idiot. Solved.
    That sounds like a metadata issue, the RSL/MDL tags are not on the thunmbnails but are added by DS according to the database entries.
