System Requirements and older DAZ downloads.
So I was here around 10 years ago. Coming back and got some questions.
I have a TON of older content. Used fig’s and props in Poser.
Looking to do the yearly Daz Premier and will be grabbing new content / props / figs “etc..”.
I’m sure I’ll have other Q’s as time rolls on but these are what I have to start with before buying / downloading.
Thanks
Questions:
Will the older DAZ content I have still work in the software ?
System requirements. Is a ... 12th Gen Intel(R) Core(TM) i5-12400 (2.50 GHz) ... and a Nvidia rtx 3060 going to drive Daz / Genesis “Daz Premier Edition” ? “Windows 11 Home latest update”
  • Richard HaseltineRichard Haseltine Posts: 111,516
    As of the end of last year Daz Studio does not include 3Delight. It can still convert the standard 3Delight shaders to Iray, with varying degrees of success, but custom shaders will simply be blank white surfaces. The oldest nVidia GPU suported by Iray has also changed 9if iray was even around then) - currently irt is the 10x0 series, but those are deprecated meaning at some point in the foreseeable future it will need at least a 20x0 card for GPU acceleration. Otherwise older content should still work, plug-ins and scripts may be more variable (depending on how literal your ten years are).
  • majikboxmanmajikboxman Posts: 10
    "The oldest nVidia GPU suported by Iray has also changed 9if iray was even around then) - currently irt is the 10x0 series, but those are deprecated meaning at some point in the foreseeable future it will need at least a 20x0 card for GPU acceleration."    Thanks for the info but do have to say ... have zero clue what you meant.
