Amelia for Genesis 9
Sunkissed PapayasSunkissed Papayas Posts: 41
edited March 14 in The Commons
https://www.daz3d.com/amelia-for-genesis-9
I actually purchased this character today, and it was a total mistake. The created photos advertising for her look like a great character. But, once you load her basic character file she looks like a big boobed crack addict. Even loading her basic files included doesn't change at all to really anything worth while. I've loaded a basic Genesis 9 Figure then added her to it, and same results. I understand that you might have to make some adjustments, but still not even a resembalance to the advertising for her in the basic load.
1024 x 768 - 424K
Post edited by Sunkissed Papayas on
    I don't have that product but it does look like it's not correct. Have you installed the Premier Exclusive Saga for Sigrid 9 addon perchance? Apparently there is an issue with that where it loads at 100% by default and so will apply to every G9 you load - see this thread for more info.  Check your currently used morphs on the figure and see if that is active - you will have to uninstall Saga for Sigrid until that product is fixed.
  • WolfwoodWolfwood Posts: 998
    Have you by chance installed the premier addon shape of Sigrid? Because there are know problems since thrusday about faulty morphs that are not zeroed.
    If you have, uninstall for now. If not, look for the faulty morph in your particular case (load base G9 only and see what morphs are active).
  • 3DSaga3DSaga Posts: 951
    Yes, there's definitely something going on there, as that's not anything how she looks for me.
  • Sunkissed PapayasSunkissed Papayas Posts: 41
    edited March 14
    Yep, I am premiere, so I'll uninstall Saga also. I purchased all the Sigrid 9 stuff also and getting the same results on it. Thanks for that info. Unloaded Saga and it fixed it. Thanks so much..
  • felisfelis Posts: 6,622
    Sunkissed Papayas said:
    Yep, I am premiere, so I'll uninstall Saga also. I purchased all the Sigrid 9 stuff also and getting the same results on it. Thanks for that info. I'll unload Sigrid and see if it fixes it.
    You need to uninstall the premier character add-on - it is her doing it.
  • Thanks for letting me know all this. She works fine now after uninstalling Saga. I actually uninstalled all of  the Sigrid stuff until they fix the add-on Saga.
  • Is this still and issue with the Saga one? I uninstalled and reinstalled and I feel like I'm not getting the same issue anymore
  • Richard HaseltineRichard Haseltine Posts: 111,937
    It should work just to zero the Sigrid shape to override the default value (but that will be needed for each character you load, I would be inclined to save a new character preset for Genesi 9 and use that to load the figure then apply shaping and materials presets for the desired character to that).
