Is Surfer Outfit Sweater Wearable?
https://www.daz3d.com/x-fashion-surfer-outfit-for-genesis-9
I was wondering if the sweater can only be worn tied around the waist. The promos, including the clay renders, only show it that way. At $1.99, it's not a deal breaker. I like the other pieces and a sweater tied like this would add some different looks to other outfits.
  • felisfelis Posts: 6,573
    If the character shoulkd both be able to wear it around the waist and as a actual shirt, it would require two different riggings. So I would say no, it cannot be worh as an actual shirt.
  • butterflyfishbutterflyfish Posts: 1,814
    I own it, and yes, it can only be worn around the waist.
  • WolfwoodWolfwood Posts: 998
    Only tied. It has some decent morphs, but sadly cannot be worn as a regular sweater.
    Of course, using something that looks similar and matching the shader can make it look like it is the same.
    I would say It is a decent extra/accesory. I got the outfit in the bundle, don't know if i would had grabbed it just alone as i have have other bikinis and don't particularly need a surf board. But If 1.99 works for you, go for it.
  • nonesuch00nonesuch00 Posts: 18,878
    edited March 12
    No, if you look at the fit adjustments in the description only adjustments for wearing on the waist are given, not any worn on the torso.
    Post edited by nonesuch00 on
  • Thanks, I figured that was the case.
  • SilverGirlSilverGirl Posts: 3,969
    I contemplated it just for the tied sweater, but the back view looks like it has a wedgie-ish thing going on with the drape.
  • nakamuram002nakamuram002 Posts: 824
    The sweater is just an "artist's concept" of a surfer outfit.  No surfer would ever wear a sweater in the water - around the waist or as a top.  Wetsuits and rash guards - yes, sweaters - no.  Maybe just for walking to/from the beach.
    Wonder if  Sickleyield's Decrackifier would fix that? But I don't have the G9 version. Oh well. I will skip it for now.
