Convergence
What are the pros and cons of using convergence to determine when a render is "finished"? I normally leave it at 95% and allow that to dictate "done".
But sometime I get a render, usually one with a lot of light splatter, that takes forever to converge, if at all.
Any tips? Best Practices?
  • Richard HaseltineRichard Haseltine Posts: 112,197
    That means, most likely, that it is running out of time or samples before converging - the log file (Help>Troubleshooting>VIew Log File) should tell you why the render stopped. A sceen with lots of areas that rely on bounced light rather than being lit directly, or with lots of relfective surfaces, or with complex shaders that can divert the path a light ray is following are likely to cause this kind of thing so you could always have a Render Preset saved for tricky scenes, with no or higher limits on samples and time. Convergence usually works, but sometimes it will fail if there is a concentrated area of the render that is harder (eyes, for example, often do this) - in that case it may hit the threshold but because the remaining unconverged pixels are in a very limited area they are much more noticeable than they would be scattered across the image.
