DIM eating my C drive
I have a pretty tiny C drive (500 GB), so a while back I moved my library to a different, much larger drive. However, recently I discovered that my C drive was almost full, and DIM installs were starting to fail repeatedly. It turns out that C:\Users\Public\Documents\DAZ 3D\InstallManager\Downloads has ballooned to a whopping 340GB.
The contents look like zip files of packages I have installed in my library. Are they just temp files? Can I delete them, or should I move that to another drive too?
  • felisfelis Posts: 6,575
    Downloads is not directly used after you have installed your content. In DIM there is a checkbox "Delete after install" (or something similar). If you tick that DIM will delete the downloads (when installed).
    Me, I like to have my content on my disks, so I keep the downloads, just have DIM pointing them to another drive.
  • frank0314frank0314 Posts: 15,114
    If you move your content off your C: and your saved .zip you will get back all of your free space. Just make sure that you are pointing DIM and Daz Studio to those locations.
    I don't see a checkbox like that. There's "Install After Download" (which I have had checked) but that doesn't seem to have anything to do with getting rid of the packages afterwards.
    I may just do that. Are they useful for restoring data in an emergency?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,698
    after checking the delete after installing option, you can safely delete all those zips, just the zips. leave the other stuff
  • Richard HaseltineRichard Haseltine Posts: 111,792
    The Install after Download checkbox is in the Ready to Download tab, the Delete After Installation is in the Ready to Install tab.
    Ah, I didn't even realize the bottom of the window was part of the tab, partly because the rest of it doesn't change between tabs, and also because (since I had "Install After Download" checked), I almost never used the Ready To Install tab. Thanks for the info!
