True to size Figure?
Greetings all,
I need to create a figure (probably use Genesis 9) to import into CLO3D.  Is there a way to create the figure to specific dimensions?  Like real life height, soulder width, waist, shoe size, that kind of thing?
  • felisfelis Posts: 6,609
    There is Measure Metrics https://www.daz3d.com/measure-metrics-for-daz-studio
    for measuring sizes.
    Though when I need sizes, I will usually use a scaled cube.
  • richardandtracyrichardandtracy Posts: 8,219
    edited March 2
    A cube is a way I did it. I created a 1m cube primitive, set the scale nudge value to 0.01/1% and then scaled it up & down until it was the size of the dimension I needed to measure. The scale was then the measurement in metres when not displayed in %, and cm when displayed in %.
    A second way is to use a measuring wall (eg SpyroRue's freebie MWall 2.0 at DeviantArt used in my attached image).
    Regards,
    Richard
    935 x 923 - 169K
    Post edited by richardandtracy on
  • lilweeplilweep Posts: 2,879
    scarecrow76 said:
    Greetings all,
    Can you do it on CLO avatar then export back to Daz for reference?
