Filament floor not showing
Hello, I am new to daz and I have encountered an issue with filament where I can no longer see the floor.
This only happens in filament (and Iray but I can't remember if I had ever seen the flooe in iray), I am not sure why it happened, this was working fine just 1h ago but stopped working all of a sudden, I read online that it could be a NVDIA software update but not sure. It's a shame as I really like working with Filament.
In any case I have checekd that I have shhow floor ticked, and the issue doesn't happen in oother modes such as Wire shaded. I have also restarted daz and reset my layout just to make sure. I have deleted and re created the filament draw options but no luck.
Any help would be greatly appreciated, thanks!
John
2558 x 1399 - 137K
1713 x 1338 - 81K
2560 x 1396 - 186K
  • The floor grid is a guide, not something that is meant to render, so this seems expected. if you want a floor then you need to add one - a plane primitive would do (Create>New Primitive).
    Iray can draw a "floor" that will hide things underneath it (if it is set to a specific height, otherwise it will move to be under everything in the scene) and will catch shadows and reflections, that is set in Environemt group of settings in Render Settings>Editor by by selecting the environment Settings node in the scene and using the Parameters pane.
  • Thanks Richard, but I am 100% sure I had a floor grid when in filament mode. Here is screenshot I had taken previously from some references I had.
    This grid is useful as it allows me to know where to put objects and how they are situated vs the y=0 plane. I don't want to put a a primitive (as that would not be infinite anyway) I just want the same grid as I had before and the one I see now where I am in Wireframe for example.
    Do you also see a complete blank gray when you go on filament on your daz session?
    496 x 502 - 32K
  • You are right, the floor grid does show in Filament Drawstyle for me. I can hide it by turnign off Draw Avatars in Draw Settings>General group, so it may worth checking if you have that setting off or on.
  • dortmund3-2dortmund3-2 Posts: 0
    Amazing! This worked, thank you so much man
    For anyone having this problem , here is a screenshot of the solution
    2560 x 921 - 140K
