How do I stop a sim update?
Hi!
How do I stop a shirt from updating arround an arm that gets close to it?
I have already froze the simulation after moving the arm away. Once i move it close again it just morphs back over the arm.
I need it to completly be the way it is with the arm up.
(also tried interactive update but that doesn't seem to change much)
Screenshots attached
1172 x 595 - 380K
1135 x 644 - 491K
  • It's not the simulation, it's the Smoothing Modifier - you have that set to collide with the base figure, so when the arm comes into contact with the shirt the smothing modifier tries to get out of its way. I would suggest turning off the collision part of the SMoothing modifier (its shown in your screenshot, set the Collsion target to None) then run the unfrozen simulation wiith the arm starting away from the body (memorise the pose or use the Timeline)and moving closer - as long as it leaves twice the dynamic offset clear between arm and torso the shirt should stay on the inner side of the arm.
