Hello, how do you do your hair in DAZ, how did you fix the problem with the hair on top?
I don't understand what this cowlick is, combing doesn't help, hair removal creates a bald spot
500 x 500 - 275K
  • I would guess those are interpolated hairs gettign odd rsults because of the directions in which the adjacent guide hairsa re pointing, though it does look as if the hair density is low which may not help. Are you able to post a scene file for others to look at, if this hair is your own work?
    duf
    duf
    test.duf
    4M
  • I am at my work computer so cannot open the duf right now.
    I will make an assumption that this thread relates to creating hair with Daz Studio's SBH Editor.  If that's the case, then hair sticking up at a part or at the crown is due to interpolated/child hairs being influenced by neighboring style guides, as Richard said.  Interpolated/Child hairs take influence from nearest (three?) style guides. One of the following will work:
    • Adjust style guides at the crown/part area (which i assume you have already tried)
    • Remake hair using a haircap with more vertices, to spawn more style guides at the crown/part area to give more control
    • Split the SBH groom into multiple different SBH grooms, one for each side of part
    • Adjust single guide settings. This should be put under the influence of a Paint map/mask (note that any part of a groom under influence of 'Single Guide' will cause issues with clumping)
    • Adjust autoparting settings
