• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Unity Discussion
DazToUnity (NEW version)(Unity 6 compatibility, runtime render pipeline)
PandaNyxisPandaNyxis Posts: 2
February 20 edited February 20 in Unity Discussion
DazToUnity Bridge
A modernized fork of the Daz3D DazToUnity Bridge, updated for Unity 6 and all three render pipelines — HDRP, URP, and Built-in.
Based on the original work by Daz 3D. This fork focuses on Unity 6 compatibility, runtime render pipeline detection, UPM packaging, and a unified uDTU shader family for all pipelines.
1. What's Different in This Fork
This fork modernizes the original DazToUnity Bridge with a focus on clean, forward-compatible code:
  • Replaced deprecated FindObjectsOfType with FindObjectsByType
  • Switched to EditorSceneManager for scene operations
  • Removed Unity 2019 dead code paths
  • Added safety around AvatarSetupTool
Runtime render pipeline detection
  • New RenderPipelineHelper replaces all #if USING_HDRP / URP / BUILTIN preprocessor directives
  • Pipeline detection is cached at runtime via GraphicsSettings.currentRenderPipeline
  • Shader names are runtime properties, not compile-time constants
UPM package structure
  • Installable via Unity Package Manager from a git URL — no file copying needed
  • Proper Runtime and Editor assembly definitions
  • SimpleJSON vendor dependency isolated with autoReferenced: false
Unified uDTU shader family for all pipelines
  • HDRP and URP: existing Shader Graph shaders (Hair, Metallic, Specular, SSS, Transparent)
  • Built-in RP: new ShaderLab surface shaders matching the same property interface
  • All three pipelines use the same material conversion path — no legacy fallback
2. How to Install
Daz Studio Plugin
  1. Go to the Releases page
  2. Download dzunitybridge.dll
  3. Copy the DLL into your Daz Studio plugins folder:
    C:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\plugins\
  4. Restart Daz Studio
  5. Verify: File → Send To → Daz To Unity appears in the menu
Unity Plugin — Option A: UPM / Unity Package Manager (Recommended, Unity 2022.3+)
The cleanest install. No files are copied into your Assets folder.
From Unity:
  1. Open your project
  2. Go to Window → Package Manager
  3. Click + → Add package from git URL...
  4. Paste: https://github.com/Knuffelpanda/DazToUnity.git?path=UnityPlugin
  5. Click Add
Or edit Packages/manifest.json directly:
"com.daz3d.daz-to-unity": "https://github.com/Knuffelpanda/DazToUnity.git?path=UnityPlugin";
From Daz Studio (automatic):
  1. Open File → Send To → Daz To Unity
  2. Enable Advanced Settings
  3. Select UPM Package (Unity 2022.3+) from the dropdown
  4. Click Install Plugin and select your Unity project root
  5. Switch to Unity — the Package Manager resolves the package automatically
Unity Plugin — Option B: .unitypackage (Classic, Unity 2019–2021)
  1. Open your Unity project and leave it running
  2. In Daz Studio: File → Send To → Daz To Unity
  3. Enable Advanced Settings
  4. Select your Unity version and render pipeline from the dropdown
  5. Click Install Plugin and select your Unity project root
  6. A Unity Import Package dialog should appear — click Import
  7. If it doesn't appear automatically, go to Assets/Daz3D/Support/ and double-click the matching package:
    • DazToUnity HDRP.unitypackage
    • DazToUnity URP.unitypackage
    • DazToUnity Standard Shader.unitypackage
  8. For HDRP: add the Daz diffusion profile to your HDRP asset's diffusion profile list (Project Settings → HDRP Default Settings)
3. How to Use
  1. Open Daz Studio and add a Figure or Prop to your scene
  2. Select the top node of your Figure or Prop in the Scene pane
  3. Go to File → Send To → Daz To Unity
  4. Select the Asset Folder for your Unity project
  5. Choose the Asset Type:
    • Skeletal Mesh — for rigged figures
    • Animation — for animation clips
    • Static Mesh — for props and environments
  6. Optionally enable Morphs or Subdivision levels via the checkboxes
  7. Click Accept and wait for the confirmation dialog before switching to Unity
Unity will automatically import the FBX and .dtu file, apply materials, and set up the prefab.
4. How to Build
Requirements: Daz Studio 4.5+ SDK · Qt 4.8.1 · Autodesk FBX SDK 2020+ · Pixar OpenSubdiv · CMake 3.4+ · Visual Studio 2017+
git clone --recurse-submodules https://github.com/Knuffelpanda/DazToUnity.gitcmake -B build \  -DDAZ_SDK_DIR=<path> \  -DFBX_SDK_DIR=<path> \  -DOPENSUBDIV_DIR=<path>cmake --build build --config Release
The build output is dzunitybridge.dll (Windows) or dzunitybridge.dylib (macOS).
Set -DDAZ_STUDIO_EXE_DIR=<path> to auto-deploy the plugin to your Daz Studio plugins folder after build.
5. How to Test
Unit tests (Windows, C++):
  • Build in Debug mode with /EHa (C++ exceptions with SEH) enabled
  • In Daz Studio, load Test/UnitTests/RunUnitTests.dsa
  • Set sIncludePath and sOutputPath on lines 4–5, then run
  • Click through any dialog prompts that appear — they are part of the tests
Automated test cases (Daz Script):
  • In Daz Studio, load Test/TestCases/test_runner.dsa
  • Set sIncludePath on line 4, then run
  • Results are written to Test/Reports/ as JSON and TXT
Manual QA:
  • See Test/QA Manual Test Cases.md for 16 test scenarios
6. How to Develop
C++ plugin (DazStudioPlugin/):
  • DzUnityAction — triggers the export workflow via File → Send To → Daz To Unity
  • DzUnityDialog — export configuration UI
  • The DzUnityNS namespace prevents collisions when multiple bridge plugins are loaded simultaneously
  • Uses CPP_PLUGIN_DEFINITION() instead of DZ_PLUGIN_DEFINITION to enable C++ class export across the bridge library boundary
C# Unity plugin (UnityPlugin/):
  • Daz3DDTUImporter — ScriptedImporter for .dtu files, drives the entire import pipeline
  • DTUConverter — material and shader assignment
  • RenderPipelineHelper — cached runtime pipeline detection, single source of truth for all pipeline branching
  • DetectRenderPipeline — manages scripting defines for backwards compatibility
Modifying shaders:
  • HDRP/URP shaders are Shader Graph assets in UnityPlugin/Shaders/uDTU/
  • Built-in shaders are ShaderLab files in the same folder (uDTU BuiltIn.*.shader)
  • All shaders share the same _-prefixed property names so DTUConverter works identically across pipelines
Updating the .unitypackage files:
  • Make changes inside Unity
  • Export a new .unitypackage from Unity
  • Replace the matching file in DazStudioPlugin/Resources/
Post edited by PandaNyxis on February 20
  • ArtiniArtini Posts: 10,960
    February 24
    Wow. Interesting. Thanks for posting.
  • zedemirozedemiro Posts: 3
    February 25
    Thanks! I whish it could work with Daz 6 though
  • PandaNyxisPandaNyxis Posts: 2
    March 6
    How do you mean with Daz 6?
  • LeanaLeana Posts: 13,616
    March 6 edited March 6
    Daz Studio 2026, also known as DS6, is the next major version of DS which is currently in beta. The code base changed a lot, notably because they upgraded the version of Qt framework used to Qt6, so none of the plugins made for DS4 work with DS2026 (and some scripts require an update too).
    The new SDK has not been published yet so only Daz Originals plugins have a DS2026 version for now. I don't think they've released an updated version of the bridges yet though.
    Post edited by Leana on March 6
    March 7
    That's good to know! Once the new SDK is published and the bridge gets updated for DS2026, I'll definitely check it out. I'm currently using Daz models in a Unity project, so compatibility with the newer version would be a big help.
  • plj1225plj1225 Posts: 40
    April 10
    Is there a way to make this work with Mac OS? 6000.3.13f1 broke all of the official bridges.
  • germanianergermanianer Posts: 5
    July 26
    Very nice work.
    It was a bit tricky to get it to work in the newer releases but it works.
    Thank you for the hard work at this extension.
    I couldn't get it to work on Daz 6.0
  • jeronimocollaresjeronimocollares Posts: 149
    August 13
    If you haven't found a solution yet, I think you should just work "the old-fashioned way": export the model as an FBX (2014) and see what you can do from there.
    Unfortunately, it seems the owners of Daz Studio have no interest in gaming, keeping everything strictly within the already insular Daz ecosystem. No "bridge" plugin works correctly—perhaps they did in Stone Age versions of Unity, but not in the latest engine.
    I’d know exactly how to help you on Windows, but things work a bit differently on Mac. Here’s a good tip: don’t use G9, G8, or even G3 models; use the G2 model exclusively if you want to avoid headaches with bones and animations using Unity’s humanoid rig (Mecanim system).
    August 27
    TY for all the advice, I decided to jump ship to Linux (Fedora 44). Unity, Blender and I've now got DAZ 4 and 6 working in WINE with a $5090$.. Great times!
    September 3 edited September 3
    Great. I did not know that Fedora still exists. Have a fun with your $5090 purchase.
    Post edited by Artini on September 3
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
